pop when...
MxStYlEpOlKmAn
every time i turn my fan off my subwoofer has like a pop...plays fine, but pops when i turn it off...could this hurt the subwoofer in newayz?
Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
I promised myself
Damn you all! - ATC
Post edited by MxStYlEpOlKmAn on
Let me get this straight,
when you turn off your fan...I assume a window or a tabletop cooling off people fan??
It's most likely on the same circuit,I don't see how it's making your sub pop.
does this happen when the sub is in standby or when your using your system?
Never heard this one before.Dan
My Velo does it to with a cooling off the people fan. Only with the fan on the same circuit though. I blame it on the wiring at my apartment. Possibly no groung is allowing interference to seep into the power lines?The guy with $40.00 mains and a $700.00 subwoofer.
my sub was on the same circuit as my ceiling fan and popped when i turned off the fan i just moved the sub too a diff outlet..no more popSpeakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2 -
sounds like an inductance problem caused by the fan on that line. I would not think grounding would be an issue here?***WAREMTAE***
Ive heard both yes and no as to whether any damage can occur
try plugging in your sub through the delay on off if this still occurs
you may want to get a line conditioner -
i plugged it in somewhere else and it dont pop no more...so whateverDamn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
