RE H/T Sub design
95Honda
95Honda Posts: 77
edited September 2005 in DIY, Mods & Tweaks
I am just finishing up a new Home Theater subwoofer. I chose an RE SE15 for the driver. Designed for car audio, but will work very good in this alignment. It has plenty of excursion and is relitively cheap. The box is 5ft3 tuned at 20Hz. I have a 1000 watt plate amp I will put on the back of the cabinet. Finish is Line-X.
www.forceaudio.com .... We cut through the BS.
Post edited by 95Honda on
  • ohskigod
    ohskigod Posts: 6,502
    edited August 2005
    Hard to see if you got bracing in that Box. I saw the other stereo subs you made (sweet) so you definitly know what your doing, but I hope you got enough bracing, because man it looks like that driver is going to need it.
    nice clean finish by the way.
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • 95Honda
    95Honda Posts: 77
    edited August 2005
    Can't see it, but it's there. Box is stout. :)
  • 95Honda
    95Honda Posts: 77
    edited August 2005
    All done, sorry about the poor image quality.
    VR3 Posts: 28,035
    edited August 2005
    Cool, very nicely built and finish...
  • Schris22
    Schris22 Posts: 983
    edited August 2005
    wow quite impressive!
    Looks good
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
  • 95Honda
    95Honda Posts: 77
    edited August 2005
    Thanks for the comments!
    I fired it up last night. Really good output down low.
  • ohskigod
    edited August 2005
    great job! looks sweet
  • audiobliss
    audiobliss Posts: 12,518
    edited August 2005
    That's looks to be sealed, no? How many watts is it getting? How low will it dig at -3db? Is it good for music, too? Looks sweet!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • 95Honda
    95Honda Posts: 77
    It's ported. Down 3db at 19Hz or so. It sounds great with music and movies. 1000 watt plate amp....
