fx 300i...
MxStYlEpOlKmAnMxStYlEpOlKmAn Posts: 2,116
edited June 2002 in Speakers
ok
when u have a setup of rt35i's mains...cs245i center and rt25i front surrounds and fx 300i has back surrounds...how would u place them on the wall?
would u put them on the back of the side wall (on each side) or would u put them on each corner of the back wall?
or would u put them in the middle of the back wall?
OR would u put them in the middle of the each side wall?
Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
Post edited by MxStYlEpOlKmAn on
  • Frank ZFrank Z Polk-a-dweeb Posts: 5,967
    edited June 2002
    U would put the FX300 speakers on the sides, and have your RT25's on the rear wall. If possible u would place them at the same height as the rt25's, about 2-3 feet above your noggin when seated.
  • scottvampscottvamp Posts: 3,297
    edited June 2002
    Frank is right on the money. That would be the best way to go.:cool:
    PS3 and HD Front Projection, life is good. Too bad Blu-Ray and the PS3 are already obsolete.....:rolleyes:
  • mantismantis Posts: 14,737
    edited June 2002
    Thats the way to go,
    fx300's as surrounds and rt25i's as surround back.
    Also the keep them at the same height makes the wrap around sound more natural.I like it.
    Dan
Howdy, Stranger!
