SL 3000 tweeters
duke1010
Hello. I need two SL 3000 tweeters for my rta speakers can anyone help? Do these tweeters blow easy or what?
NO, they don't unless you overdrive or distort them."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
more than likely, they were underpowered and distortedLudicrous gibs!
Hi everyone. New to the forum since picking up a pair of SDA-2B Studios ...that I love. The previous owner upgraded the tweeters to SL-3000s. Does the crossover need to be modified to use them?
billunderhill wrote: »Hi everyone. New to the forum since picking up a pair of SDA-2B Studios ...that I love. The previous owner upgraded the tweeters to SL-3000s. Does the crossover need to be modified to use them?
To be used correctly yes there would need to be some cap work done. -
You'll have to do the TL mod. A search should bring up all the info you need.Political Correctness'.........defined
President of Club Polk -
Wow, two faces from the past, Noah and ND13... this place sure has changed
Oh and welcome back Jesse, glad we can see you posting again.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Thanks Harry, good to see you too.Political Correctness'.........defined
Are the SDA2b-studios the same as SDA2b's ? Wouldnt he be better off to put RD0194"s in them ? I understand its time to refresh the crossovers as they are beyond there time. shouldnt there be SL2000's in them ? Just wondering herePost edited by boston1450 on..
Randy/Maine -
No, yes, and yes in that order.
My bad. i thought the 2b Studio's had the same crossover as the 2b & crs+ ...
Randy/Maine -
They do, but SDA 2 is a different animal. Actually its what I'm listening to now.
And she keeps turning them down -
So it is the same crossover. They do take sl2000 tweeters. The drop in replacement is the RD0194 tweeters.... To use the sl3000 tweeters you would need to modify the crossovers & then you could use the RD0198 tweeters. Have i got that correct..
Randy/Maine -
boston1450 wrote: »So it is the same crossover. They do take sl2000 tweeters. The drop in replacement is the RD0194 tweeters.... To use the sl3000 tweeters you would need to modify the crossovers & then you could use the RD0198 tweeters. Have i got that correct
Yes -
To use the RD0198 you would need to parallel a 5.8uF cap with the first 2.7ohm resistor and remove the second 2.7ohm resistor. However, I can't say how the TL mod would play with the 6510 mid-drivers in the 2A's.Political Correctness'.........defined
Thx nice info. I couldnt remember info on them. I had the 2a's & 2b studio's + they came & went. I kept the 2b & 1c speakers which i did upgrade the tweeters. Far better upgrade..
Randy/Maine -
The 2B Studio and 2B are exactly the same with the exception of the cabinets.Political Correctness'.........defined
The SL3000 tweeter upgrade is the RD0198 . here is my quick review. I changed one out in the 15tl & turned the Adcom on & BIG then i shut er down & put the other one in quickly. What a noticable difference..
Randy/Maine -
^ No doubt ^Political Correctness'.........defined
