RTi with new CS
eaadamseaadams Posts: 213
edited May 2002 in Speakers
So I have some RT 35i's that I like a lot and the look. I want to get the new CD40i becuase it's height is PERFECT for where I need to place it. Will they match ok or should I upgrade (as I can for one year from purchace at CC) to a new bookshelf. My main concern is I was hoping for a replacement to the 55i and to upgrade to that. What do you all think the best course of action is?
Evan Adams
Sacramento, CA
Post edited by eaadams on
  • TroyDTroyD Posts: 12,638
    edited May 2002
    If you like the RT35i, get the new center and check it out. I think you will find that they will go together quite well....
    If it ain't broke, don't fix it.
    Troy
  • goingganzogoingganzo Posts: 2,797
    edited May 2002
    i would say get the center and if it sounds good then dint trade out the 55
    Gonzo's World
    BenQ 8700+
    115in screen
    PS3,X-Box 360 and Wii
    Sunfire Theater Grand III
    ADCOM GFA-7607
    four avalanch 18 subs 26.12l of displacement
    Crown xti 4000
Howdy, Stranger!
