Active xover with SDA's?
madmax
madmax Posts: 12,434
edited May 2002 in Speakers
Anyone tried an active xover while bi-amping the SDA's? It's working but even if I overlap the frequencies I'm still loosing midrange. Seems like they overlap A LOT in their standard configuration. A LOT!
madmax
Vinyl, the final frontier...
Post edited by madmax on
  • gidrah
    gidrah Posts: 3,049
    edited May 2002
    I hope (will assume) you have the x-over set to 2-way.
    I didn't know the SDAs were Bi-ampable. Good to hear.
    Make it Funky! :)
  • madmax
    edited May 2002
    I have it set to two way. Any of the SDA's beyond the 1C's can be bi-amped. They actually sound a little cleaner and more detailed with the xover in place but they are loosing something as well. Maybe this is the way they should sound? I'll keep playing with it.
    madmax
