DVD Player...
har_navalta
Anyone have a DVD Player that has 5.1 ouput?
Please tell me what brand and which model you have if theres
any. I want to buy one with at least a good quality. Please give me idea?
Thanks,
Har
Thanks,
Har
Post edited by har_navalta on
Denon DVD-A player... DVD3300.
It is an audiophile dvd-a player using Burr-brown DAC's.
It also has bass management built into it.
Now, they can be found for abour $450.
Originally, they listed MSRP for $1200.
GREAT DVD PLAYER ! ! !
And, yes, it has 5.1 outputs as well as optical and dig-coax.
Any player with a built-in decoder probably has 5.1 outs. -
Thank you... rskarvan, for the info. I'm dying to hear 5.1 but my
dvd doesn't have this outputs. I went to their site and they have
excellent specs that I'm looking for. The model that you mentioned
was already discontinued and they have a new version for that the DVD 3800 which is $1199.
I will look for other brand that matches their specs with less
money if there's any.
Thanks again for your input.
Har -
No outputs? Weird. well, unless it doesn't even work on 5.1
Does your reciever have built in 5.1? -
har,
what DVD player do you have ? do u mean 5.1 analog outputs to plug into a 5.1 "Ready" receiver??
i believe the toshiba 3109 has 5.1 outputs. You should be able to find one on ebay for well under $200. -
I got my Pioneer DVD 550 a year ago, which is Dolby Digital, DTS, Dolby Prologic, 2-Channel RCA Output, Optical Digital Output (Fibre Optic) and it doesnt have 5.1 Channel Surround Output. I dont know this option until I had my Preamp that has 5.1 inputs in it.:mad:
Most of the current DVD players if they have the DD and DTS decoder built-in, they will have the 5.1 analog (RCA) outputs , and you can connect them to your Pre or receiver 5.1 inputs. The Pioneer DVD-550 is a pretty good DVD player, if I'm not wrong is also has a mixer built-in for Karaoke. The optical digital output carried both DTS and DD signals, so if your receiver has DTS and DD decoder built-in, you can enjoy these sound tracks, if not you may consider to buy one, instead of investing money on another DVD player...
