Amp for 5.1 RTIA's
  • cfrizz
    cfrizz Posts: 13,415
    edited November 2018
    Bgoodfella wrote: »
    cfrizz wrote: »
    The Sunfire will make your speakers very happy. I should know I have one! :)
    What speakers are you using with the sunfire?[/quote
    Polk S60 Main Speakers, Boston VR-920 Center Channel, Polk FXi-3 Surround Speakers.
    I originally had a Parasound 1500A 2 channel 200wpc amp driving just my front RTA-8Tspeakers which is what introduced me to what a powerful amp can bring to the table.
    I wanted all of my speakers to powered to their full potential which is how I ended up with the Sunfire I have, which is the 405wpc 5 channel version.
    If I had come across the 200wpc Sunfire version first, I would have scooped that up.
    My amp powers all of my speakers with ease with power to spare when needed and runs very cool, and only weighs about 40lbs.
    The beauty of having a separate amp is that you can keep it through all other upgrades to your system.
  • mark090852
    I would also consider the newer Emotiva amps, probably not the gen1 amps, as many agree they’re a lil bright.
    I agree, too, with the "newer" Emotiva amps. I have a XPA 2, gen 3, and it has sounded great with my LSim 703s and also my S 20s. Nice warm sound, not bright at all.
    McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
    tonyb Posts: 32,906
    400 bucks is a good price for that Sunfire, if it's still available One might think there is a problem with it.
    Ask the owner some questions, like if there is any hum or static sound to the amp. If it's ever been worked on, and that all 5 channels are quiet at all volume levels , no added noise. Is he the original owner.
  • Bgoodfella
    tonyb wrote: »
    The owner of the amp said that there is no hum or any noise coming from the unit, the only thing wrong with it is that the light on the joule meter is out, but other than that he is saying it works perfectly on all 5 channels... he doesnt have it posted for 400 but when i offered 400 he said he would take it since he already sold all of his martin logan speakers since that set up doesn't fit in his new place.
    (2) Rti A7's
    (1) CSI A6
    (2) FXi A6's
    Denon AVR - X4300H
    Monster 850i interconnects ( not sure what everyone hates about these - maybe my untrained ears are too innocent to know what's bad)
    Parasound HCA2205A amplifier
    Sony XBR65X900E TV
    pitdogg2 Posts: 24,579
    Meter lamp is common problem. In the past with old Carver Amp's that had the incandescent pig tailed lamps they were replaced with LED might be an option for the Sunfire.
    tonyb Posts: 32,906
    Bgoodfella wrote: »
    tonyb wrote: »
    Good to know, that's a great price for that amp, go get it.
  • cfrizz
    Get it while you can!!!!
  • Bgoodfella
    I'm trying to work out a time to meet up with him, it's a struggle since we have very busy schedules and they are opposite of each other haha
    (2) Rti A7's
    (1) CSI A6
    (2) FXi A6's
    Denon AVR - X4300H
    Sony XBR65X900E TV
  • Bgoodfella
    I'll have to look into it, but to be honest the less lights distracting me from the show or movie, the better :-p definitely not a deal breaker for me
    (2) Rti A7's
    (1) CSI A6
    (2) FXi A6's
    Denon AVR - X4300H
    Sony XBR65X900E TV
  • FestYboy
    FestYboy Posts: 3,861
    The NADs you listed are 2 channel units rated at 100wpc and 200wpc. The 2400 sits at 150wpc. All amps of that era are built with ridiculous amounts of headroom, easily surpassing their rated output. Good 2 channel units. I was thinking more along the lines of their multi channel amps and more specifically the master series.
  • Bgoodfella
    FestYboy wrote: »
    I'm not too familiar with NAD, but those are pretty much all that was near by
    (2) Rti A7's
    (1) CSI A6
    (2) FXi A6's
    Denon AVR - X4300H
    Sony XBR65X900E TV
  • Bgoodfella
    What is it that gives amps the headroom? Is that something to do with watts?
    (2) Rti A7's
    (1) CSI A6
    (2) FXi A6's
    Denon AVR - X4300H
    Sony XBR65X900E TV
  • FestYboy
    It helps that they under rate their output. The output power caps and transformers are oversized as well.
  • gp4jesus
    gp4jesus Posts: 1,969
    Bgoodfella wrote: »
    i could be wrong, but im seeing 5 channels on the listing for the 1205a.
    The 1205 is essentially a 5 channel Parasound HCA-1000A. If you happen across another, take it from me, your LCR will like it. So will your surrounds.
    Tony
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
  • Bgoodfella
    gp4jesus wrote: »
    Bgoodfella wrote: »
    Tony
    Thank you for the info, I still havent decided on an amp yet. I was trying to make it out to check out the sunfire cinema grand amp this weekend but the circumstances didn't allow it. Part of me keeps going back to the HCA-2205, but part of me is back and forth if i will even notice the difference from the sunfire to the parasound in mainly home theater. The other reason I've been thinking about the HCA2205 is, i could use the 3 for my mains for HT, and save the other 2 for a 2 channel music set up in another room - maybe with some LSIM's that i keep looking at online...
    Decisions decisions.
    (2) Rti A7's
    (1) CSI A6
    (2) FXi A6's
    Denon AVR - X4300H
    Sony XBR65X900E TV
  • Bgoodfella
    Sorry to revive this forum from the dead, but I missed out on the sunfire when I finally went to go get it -it was sold :(
    Currently i am looking at a parasound hca 2205a from California . I know these are getting to be old amps now days, is 800 a fair price? I've seen several old forums where they are selling around 600 to 700, but also seeing some on ebay for 1200 ish.
    Also I keep waiting for adorama to do more polk lsim package deals so I can snag one but I haven't seen anything for almost a year! If they do come back around, would the 2205 be a good amp for them?( 707 or 705, 706x and 703 or the FX for the back 2)
    (2) Rti A7's
    (1) CSI A6
    (2) FXi A6's
    Denon AVR - X4300H
    Sony XBR65X900E TV
