Quel amplificateur ???
Bonjour j’aimerais votre avis sur un bon amplificateur à utiliser avec mes hauts parleurs, oui j’utilise 2 sub , je pensais faire l’achat du Yamaha RX-V1083
RTI A9
CSI A6
RTI A1
RTI A5
HTS 12
PSW 125
RTI A9
CSI A6
RTI A1
RTI A5
HTS 12
PSW 125
Best Answers
Ce récepteur serait un bon choix, mais ces grandes enceintes nécessiteront un amplificateur séparé pour obtenir le meilleur son possible.
Parlez vous anglais? Sinon, vous voudrez peut-être utiliser Google Traduction, comme je l'ai fait. -
The A9s really need an external amplifier, not just an AVR, with about 200 watts per channel or more.
The yamaha will sound better than the Onkyo, but still does not have nearly enough power for your speakers.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer
Answers
Si Senor.2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
The best way to predict the future is to invent it.
It is imperative that we recognize that an opinion is not a fact.
Imagine making politics your entire personality. -
Know i have a Onkyo 757 and i want something better
Witch one should be better for me ??
the yamaha is MUCH better, but you really still need a separate amplifier such as this: https://www.audioadvisor.com/prodinfo.asp?number=PAC2250V2&variation=BLK&gclid=EAIaIQobChMIqvuR3c_P3gIVXZ7ACh1T9gd3EAQYASABEgINc_D_BwELiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
So the RX-A2070 is better ?? Because i found the 2070 for 1499$ and the 1083 for 999$
I would get the cheapest yanaha, denon, or marantz that has preouts and use the rest of the budget to buy an external amp.
None of those receivers will properly drive your speakers.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
