Hybrid system follow-up
mdaudioguy
A follow-up to my earlier post, Hybrid system - experimenting and learning...
The basics of my hybrid 2-channel/HT setup are now in place, and working pretty much as I had hoped.
2-channel chain
Squeezebox Touch w/ Welborne Power Supply
Marantz HD-DAC1
Marantz PM-14S1 integrated amp
Vienna Acoustics Haydn Grands
Sunfire HRS8 subwoofer
Home theater chain
55" LG OLED (1080p model from a few years ago)
DirecTV and Roku 3
Marantz NR1608 AVR
Marantz PM-14S1 (in power amp direct mode - powers left and right channels)
Vienna Acoustics Theatro center channel
Niles Audio DS7FX in-ceiling surround effects speakers
Connections
DAC to amp and AVR to amp via Signal Cable Analog Two ICs
Amp to main speakers and amp to subwoofer (speaker-level inputs) via Signal Cable Ultras
Squeezebox Touch to DAC via Signal Cable Silver Resolution Digital Coax
Center channel connected with economy speaker cable from Amazon
Surrounds connected with standard in-wall 14 gauge cable
This system will most likely stay in this configuration for a while. Next upgrade steps will probably be power cables (I did run two dedicated 20-amp lines), power conditioning, and possibly speaker cable/IC upgrades.
The subwoofer is also probably not my endgame solution. Since I have it connected via speaker-level inputs (because the VA bookshelves could use a little help in 2-channel operation), my HT is actually 5.0, with all speakers running large. I'm assuming that without a sub, the AVR sends the LFE output to the L&R main channels, which are tied to the sub (crossover set manually with the sub's dial). So... I don’t feel like I’m losing any performance there. Please enlighten me if I’m wrong. I do feel that this sub is an excellent performer for HT, but not necessarily as musical as I'd like it to be, so I'll be on the lookout for something else at some point.
Overall, this is the finest sound I’ve ever had in my home. I’m very pleased!
My only gripes? The Marantz integrated can only switch between modes by pressing a button on the front panel and holding for 3 seconds. There's no way to do this remotely. So yeah, I have to get up to do that. I’ve been making sure to leave it in HT mode, since I'm the only one who uses it for music. Funny thing is, if I forget and leave it in 2-channel mode, anyone who wants to watch TV only hears the center channel and surrounds, and they usually don't even notice!
Also, Marantz chose to use the same remote control codes for power on/off and volume for the integrated amp and the AVR. I use a Harmony remote, but it’s basically only good for HT operations. I don’t use it for 2-channel use, since it also powers on the AVR unnecessarily.
2-channel chain
Marantz HD-DAC1
Home theater chain
DirecTV and Roku 3
Marantz NR1608 AVR
Connections
how about trying Signal Cable Silver Resolution from dac to amp?
30 day home try out.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Speaker Cables: Organic Audio Organic Reference 2
Interconnects: Argento Organic Reference 2, Argento Organic 2
Puritan PSM156 -
30 day home try out. -
since you have signal cables this is the next progression in their line and should be an improvement. if not send them back and start down the rabbit hole with different brands ($$$)Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I put a couple panels up last week to manage reflections on the right side. Left side is open to a larger area. I think it was successful as things seem more stable, centered, and balanced now.
Update:
New subs, power cables, speaker cables, mini PC
2-channel chain
Marantz HD-DAC1
Martin Logan Dynamo 700w
Home theater chain
DirecTV and Roku 3
Marantz NR1608 AVR
Connections
Wireworld Aurora 7 power cables for Marantz amp and DAC
Amp to main speakers via Wireworld Mini Eclipse 7
Amp to subwoofer via AudioQuest Black Lab for 2-channel, wireless for HT
Surrounds connected with standard in-wall 14 gauge cable (not gonna change)
Home theater sources
DirecTV
Roku 3
Intel NUC 7i5BNH -
If you want a system that does it all, cable management will be a challenge. I'm not yet sure how to deal with this mess of power cables, speaker cables, interconnects, and Ethernet cables...
Anyhow, I really like where things have gone with the Wireworld power cables and speakers cables. Glad I made that investment. If I upgrade any more power cables, I guess it would be the subwoofer PC. The stock cable looks fairly basic and smallish. I really don't care about the HT PCs.
2-channel ICs and a digital coaxial cable will be likely be the next, and close to final, upgrades. Gotta be Wireworld at this point. Oh yeah, and even though HT is not really a priority, I'd like to upgrade that center channel speaker cable. -
What length cable you need for the center? I had Doug make a custom cable for me, but I no longer have an HT. It's bi-wire on both ends (but I didn't use the amp end bi-wired), but it's pretty short...maybe .5m. Shoot me a pm if you'd like more info. I'd let it go fairly cheap to a good member since it's just sitting in my closet. Actually have a great center and surrounds that I need to list for sale.Things work out best for those who make the best of the way things work out.-John Wooden
@PSOVLSK Gotta love this place! Post a need and someone offers to help. You see it all the time.
That cable sounds good, except for the bi-wire part. I'm going to hold off for the moment, since my center is not bi-wireable. Of course, @DSkip talked me into some bi-wire cables for my mains (same posts), but the Wireworld ends are interchangeable and we did bananas/spades on the bi-wire speaker end, and the amp end has just a single pair of spades. I'd prefer to make this connection simpler. -
Yeah, I had it custom made along with a pair for the front speakers. I shouldn't have gotten the center cable bi-wired, at least not on the amp end. Not one of my better decisions, but luckily I was able to make it work. I really hate that I no longer have an HT in which to use the cable. First time in about 20 years I haven't had an HT with a center and surround sound. I miss it.
Great looking system(s) you've put together. Best of both worlds!Things work out best for those who make the best of the way things work out.-John Wooden -
Found it quick. It’s 6’ with bananas all around.
Shouldn't I have asked you about this a week or two ago??
