Tuners Yamaha, NAD, Rotel ,Onkyo
geppy1
I have several tuners that I have had for years and do not use much. I hung onto them because they are all good tuners and one never knows when you might need to match something to an amp or preamp but it is unrealistic to hang on to all these They all work and are in nice shape with some slight footmarks on top of a couple of them.
NAD 412 Award winning tuner that is very simple and very good. It can be remote controlled but only through the NAD link system used in integrated amps such as the 314 317 350 340 370 or preamps 114 116 160 162
asking $65
Rotel RT940 This is the 2nd one I have owned and really like them I can be remote controlled but I do not have the remote however most universals will run it. Asking $60
Yamaha TX 930 Very good tuner It is working the display is just not as bright as the others in the pictures Lot of options on this one and it can be remote controlled but I do not have the remote Yamaha system remote will run it or a good universal. Asking $75
Onkyo T4000 Nice basic tuner that sounds pretty good. Can be remote controlled through Onkyo IR system.
Asking $35
asking $65
Asking $35
@Clipdat Drew weren't you looking for a tuner recently? Smoking deals here!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
That TX-930 is tempting, but I am happy to yield to anyone who needs a tuner... I don't need another tuner...
Bump
I've really been enjoying the tuner in my Rotel RTC-940AX, same as geppy1's stand-alone, I believe. Can confirm that the Harmony 350 universal remote is compatible (and cheap, too). Thanks for that tip, geppy, and GLWS!
Bump
