2 amps 1 pre ?
rburgess714
rburgess714 Posts: 614
Can you use 1 pre for 2 amps if one amp is connected to pre via RCA and the other XLR. Not running both amps at the same time ?
Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Yamaha BD-S681, Cambridge Audio Azur 851N, Polk S60, Polk S30, Samsung 60" LED
Office
Cambridge Audio 851A, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables
Best Answer
  • rburgess714
    Answer ✓
    DSkip wrote: »
    I'd contact the manufacturer. The North Star gear only outputs either/or but I'm not sure about the P5.
    I can do that. Thanks Skip.
    Living Room
    Office
Answers
  • Yes, you use 1 pre for 2 amps with one amp is connected to pre via RCA and the other XLR. You can run both amps at the same time too. I did that with my P5, B&K reference 50, and B&K reference 50 S2 preamplifiers. Most of the time I only turned on only 1 amp but once a while I turned both of them on (yes, I am crazy) and never had any problems at all.
    Living room
    Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
    Player: Oppo 95.
    Amps: Bryston 4B SST, B&K Ref 200.7 S2.
    Pres: B&K Ref 50 S2, Paraound P5.
    Subs: Dual Rythmik F15HP subs.
    Man Cave
    Speakers: Martin Logan Vistas.
    Player: OPPO 105.
    Preamp: B&K Ref 50 S2.
    Amp: B&K Ref 125.2 S2
    Sub: Rythmik F12.
    Sub management: SMS-1.
    Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
    Room treatment: GIK Room Kit #1.
    pitdogg2 Posts: 24,480
    Yes but as skip stated some are switched and you can only use one or the other at a time.
  • pitdogg2 wrote: »
    The OP have P5 and B&K reference 50 preamps so he can hook up either his preamp to 2 amps.
    Living room
    Player: Oppo 95.
    Man Cave
    Player: OPPO 105.
    Sub: Rythmik F12.
  • Thanks for feedback.
    Living Room
    Office
