13.2 Channel Marantz?
Kingkwas
What is the point of a 13.2 Marantz pre Amp. What is the most channels a movie will play? 7.1?
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
R: Def Tech
DVD: Oppo UDP 203
Future proof....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Right now with Atmos (*.*.4), the pre can control 11 channels with 2 additional LFE channels. The extra 2 channels are for left and right wide. Or it can be used for a second stereo source and room.
Actually, until Dolby started having a p*ssing contest with the manufacturers, the 7702/7702MkII will both do 9.2.4 making it 13.2.
But the point is for Atmos.
9 base layer channels...L, R, C, Left Wide, Right Wide, Left Surround, Right Surround, Left Rear, Right Rear
2 subwoofer channels...
4 Atmos overhead channels...OHFL, OHFR, OHRL, OHRR
Right now, the wides are a mixed channel using left and right front blended with left and right side surrounds.
The subwoofer channels are also a blended layer. Most movie soundtracks (TrueHD Atmos) have a single sub channel. Essentially 7.1 with an Atmos layer."Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
I can't count past 2 channel.2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
The best way to predict the future is to invent it.
It is imperative that we recognize that an opinion is not a fact.
Imagine making politics your entire personality. -
It’s not just Dolby Atmos. It’s also DTS X and more importantly Auro 3D-which is where all of the extra channels come in. Btw all of the above height enabled, object based surround formats are capable of far more than just 13 channels. Future proofing is a good explanation, however it doesn’t go far enough. I would love to have this particular preamp myself.
