SDA1b (or early c) - opinions?
JayMX
Picking these up tomorrow for a song. No interconnect, but can build one. Opinions? Suggestions? Thoughts? Where do these fall on the ol Polk desirability scale?
Current Collection: Monitor 4a (Peerless), Monitor 5B (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), SDA CRS+ (194’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩
What are the differences between the 1B’s & early 1C’s other than driver loading?
Current Collection: Monitor 4a (Peerless), Monitor 5B (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), SDA CRS+ (194’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩 -
Looks like the SDA 1C uses the MW6511 for stereo drivers and 6510 for dimensional, 1B seems to use MW6509 for both. I’d guess one is easier to driver, or something.
Value wise? No clue. -
Completely different generations. The 1B is 3rd, 1C is 4th. 1C is more desirable, and relatively easier to drive. 1B is 4 ohm, 1C 6 ohm nominal.
Some early 1Cs used leftover circuit boards from the 1Bs.Home Theater/2 Channel:
dhsspeakerservice.com/ -
🤦🏻♂️Missed that, sorry. -
westmassguy wrote: »Completely different generations. The 1B is 3rd, 1C is 4th. 1C is more desirable,....
So they may be C’s even if they are blade/blade... if are loaded with 6510’s & 11’s they should be usable with isolation transformer/mono blocks? Correct?
Those serial numbers indicate that they can't be used with monoblocks.
https://us.v-cdn.net/5021930/uploads/attachments/6/4/8/2/8/9806.jpg
These don't appear to be compatible with the isolation transformer.
NOTE: Some early units of SDA-1C and all units of SDA-2B require plug adapters and some internal modifications to the crossover to be used with the Non-Common Ground Amplifier Interface. The affected SDA-1C units can be identified by serial number as follows:
Right Channel #6001 through 6310 and #6501 through 6678 Left Channel #5975 through 6370 and #6532 through 6656
If the serial numbers of your speakers fall within these limits, please contact Polk Audio for modification details. -
perfect. This helps me with determining what to offer the guy selling. The cabinets look rough, hoping to get them for less than a Benjamin! We will see what this afternoon holds. Thanks all.Current Collection: Monitor 4a (Peerless), Monitor 5B (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), SDA CRS+ (194’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩
@la2vegas - if I actually sang, he would prob kick me out. He mentioned a hundo, ima see if I can talk him down a bit. Wish me luck!Current Collection: Monitor 4a (Peerless), Monitor 5B (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), SDA CRS+ (194’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩
Definitely B’s loaded with 6509’s. Pretty thrashed. Two bad tweets, three locked up mids. Cracked cabinet. Rough vinyl veneer. And free cobwebs! All for $80!! I will bring them back from the brink of death though. This I swear. 🤘🏻
Halloween specials right there. Can't wait to see the resto-mod.Don't take experimental gene therapies from known eugenicists.
Nice find @JayMX ! Nothing that can’t be fixed! Just needs some love. Be sure to document your journey!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
The very first SDA’s I ever owned were a pair of 1b’s that looked just like these. They forced me to buy a new Receiver as the impedance dips pretty low on these. I had a Realistic receiver (remember THOSE???) when I got these and it would play just fine until I turned up the volume. Then you would hear a loud *clack* come from the receiver and the sound would cut out (meaning the protection circuit would disconnect the amp from the signal path) Once I turned the volume down the sound would come back. I replaced it with an NAD receiver and was very happy (at least until a friend who liked to brag about his Luxman receiver accepted my challenge to bring it over and I discovered it sounded way better than my NAD! )
Dennis Gardner wrote: »Those serial numbers indicate that they can't be used with monoblocks.
https://us.v-cdn.net/5021930/uploads/attachments/6/4/8/2/8/9806.jpgThese don't appear to be compatible with the isolation transformer.
In fact, if you're making your own interconnect cable to go with your Dreadnought, you just tie the ground side of the transformer to the negative binding post and you don't need the eight inches of wire inside the cabinet.
Seems the "hot tip" is to remove the OEM socket for the interconnect cable, and replace it with a Speakon-style connector, so again you'd need a little wire added inside the cabinet.
Many ways to skin this cat--IF these are early 1Cs. If they're 1Bs, you're pretty well screwed in terms of an isolation transformer.
http://forum.polkaudio.com/discussion/131691/2b-and-early-1c-ai-1-modifications#latest
Given the very-low serial numbers, I expect these are 1Bs, but a look at the midwoofer model numbers will confirm.
I've had 1Bs since about 1986, bought them as "store demo" when the 1B was being replaced with the 1C. They're terrific-sounding speakers, even moreso when the crossovers are gone through, and you pull all the Dacron back up where it belongs, add the updated tweeters, etc.
Ummmm......."Definitely B’s loaded with 6509’s."Political Correctness'.........defined
President of Club Polk -
So I’ve finally got these to a point where they’re somewhat decent to look at. And they work for the most part. I went through all eight of the MW6509's, six of which were locked up. I aligned and glued all of them. When I finally reassembled I found that I didn’t do a good job on one of them. How hard is it to break the bond on loctite red and powergrab?
I fixed up the cabinets and veneered them. Think they turned out ok...
one PRis leaky. Glued it with shoe goo. Anybody got any spares? 😂
The power grab will be the worst of it. Just break loose the pole plate and align from there with your PVC rig.
Nice job! They look great!Gustard X26 Pro DAC
So I’ve finally got these to a point where they’re somewhat decent to look at.And they work for the most part. I went through all eight of the MW6509's, six of which were locked up. I aligned and glued all of them. When I finally reassembled I found that I didn’t do a good job on one of them. How hard is it to break the bond on loctite red and powergrab?
Leave the magnet attached to the basket. Then clean up the pole piece and the facing part of the magnet. Center the pole piece in the voice coil, instead of trying to center the pole piece AND the magnet.
Great job! They look fantastic.
Like breathing life into Frankenstein
Great work2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I forgot I had this photo. This little one was building the webs...
AAAa cute! Momma must be near by though...Gustard X26 Pro DAC
Fabulous job! Especially considering the condition when you started! Looking good!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Excellent work! They look great.
Coincidentally, my evening started...sorta similarly.
I have 8 extra 6510's I plan to glue up, started with these 6. One driver in perfect condition, when I finished I snagged it with my nitrile glove and pulled it off the table. I juggled it for a split second and it hit the floor....magnet shifted and completely frozen now.
I'm pretty sure my 10yo heard a new word from the other room...
I'm also going to start re-aligning a few original drivers from my 2B's and some spares..now I have an extra to practice on.
Very nice work. Not very many people would have taken on that project.
Nice work on those cabinets Jay, quite a transformation!
Those went from fugly to eye candy. Nice skills.Don't take experimental gene therapies from known eugenicists.
