I need speakers for the 1.21 gigawatt amp I've been dreaming of...
I like it LOUD! (So I can feel it, because I can't hear good.) Please advise!
    nooshinjohn Posts: 25,100
    Cerwin Vega D9's...
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Cerwin Vega D9's...
    Do they come in stereo pairs?? Will they handle 1.21 gigawatts EACH??? >:)
    pitdogg2 Posts: 24,579
    :D:D:D
    But they may need to have a resistor upgrade. I'd suggest something on the lines of Duedorfmillshay's 2112 watt 60k ohms
    mhardy6647 Posts: 33,046
    You need 2.42 gigawatt speakers for that amp, since they're stereo.
    All the cool guys know that.
  • CH46E
    CH46E Posts: 3,550
    O'riley's has what you need. Just search for part number 121G in their website.
    If you just want loud as all hell go with some PA speakers. Cheap and powerful.
  • mdaudioguy
    edited October 2018
  • mdaudioguy
    :D:D:D
    Every time my wife walks in, I can't resistor! :p
    Neither can I :p;)>:)
    LMAO!!!
  • mdaudioguy
    Also, can you imagine that song CRANKED to like 1,000 decibels like my dream amps will surely do?!?!?!!!!!!!!! B)
    I have done it with my tube amps and SDA’s... definitely a moment that makes you proud to have a setup like that. It was a holy KRAP moment.
  • CH46E
    CH46E Posts: 3,550
    mdaudioguy wrote: »
    So.... what are these monster amps you are sourcing?????
  • lightman1
    lightman1 Posts: 10,776
    I have a Miller 440 amp arc welder that fits the bill.....
    I'll throw in a brick of 1109......6011 ;) sticks to make sure of good connection
  • mdaudioguy
    CH46E wrote: »
    mdaudioguy wrote: »
    I'll let you know when I get back to the future. :)
  • mdaudioguy
    This would be appropriate to blast!
    https://youtu.be/KCkgYhtz64U
  • mlistens03
    mlistens03 Posts: 2,767
    CH46E wrote: »
    mdaudioguy wrote: »
    Pretty sure he bought them out of the back of a van... :D
  • machone
    machone Posts: 1,476
    Can we spray paint it black?
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • stevep
    stevep Posts: 328
    edited October 2018
    You need a pair of these.
    machone wrote: »
    Oh, come, now! You should know the answer to that!
    http://forum.polkaudio.com/discussion/29186/where-to-buy-black-paint/p1
  • Wardsweb
    Wardsweb Posts: 904
    Here is the amplifier you want. Pivetta Opera Only
    so -- reflecting upon the OP.
    1.21 gigawatts (1.21 x 10^9 watts) is only a little less than 71 dB more than 100 watts.
    I mean -- yeah -- that gives you some more headroom, but it may still not be enough for that techno bass or orchestral transients, you know? I mean, especially with low sensitivity loudspeakers, you know?
    Tony M Posts: 11,017
    edited October 2018
    ^^^ Looks like something from CERN.
    ... and this is what happens when you try to use the CERN hadron collider with a pair of Infinity IRS Beta loudspeakers. Before on the right, After on the left.
    I was thinking it looked more like this
    ... and that is "hadron" -- gotta be careful when I type that, else Vanilla will censor me :p
    Viking64 Posts: 6,690
    Yeah, that would be quite the boner.
  • Mikey081057
    Mikey081057 Posts: 7,127
    These should work
    Garage | Polk Monitor 5B's
    These should work
    or... there's always...
