Is there a way to build-in LSiM over a fireplace?
Just would like to hear suggestions and perhaps someone has already done that.
I have a 5.1 system consisting of LSi9/M/FX. Recently moved to a new house and would like to hang a TV over a fireplace. At the moment it's all brick but I don't like it so it will be "re-skinned" anyway so I'm curious if anyone has ever set up LSiM over a fireplace.
Thanks!
Thanks!
If you have a shelf, it'll be perfectly fine, as long as it doesn't get too hot there.
If you're asking about building it into the wall... I wouldn't.
Welcome to Club Polk! -
Short answer is...no. You really don't want them up that high anyway, unless you want to install wall brackets and angle them down. That also includes having to run wires up the inner walls.
Maybe pop up a pic, says more so we can see what you have to work with.HT SYSTEM-
lsi 9's -
I absolutely despise the TV over the fireplace trend. Looks cool, but is the worst place for it.
Well it depends on the height of the fireplace. If it’s low and gas, then you might be able to mount the center more or less ear height and tv not too high. But I agree with Dave that if the tv has to be well above eye height, then it’s not very visually appealing or easy to see without a crick in ur neck. And yes, tony is right that wires are also an issue, but if your already running wires for a tv then it might not be a big issue...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Me, I don't like the TV over the fireplace either, give a sore neck.
LSIM are rear ported so they need room to breath. Putting one on a shelf won't give enough room. They are also heavy, so the shelf would require good mounting which might be an eyesore.
With that said it can be done, you might not like it and be stuck with it.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
With the power port mounting against the wall should be okay. But yes it needs to be angled at the seated ear level....Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
TV's do not belong over the fireplace.Political Correctness'.........defined
President of Club Polk -
Agreed....especially a wood burning one. Too high for me also, but some simply like the look rather than functionality. I'd rather be comfortable watching TV, than worrying about aesthetics....or if it looks like that magazine ad.
Then of course is the problem of retro fitting a HT system, with all it's wires, speakers, and a center channel that never fits on a mantel. All the electronics too.
Your best bet, if you want a TV over the fireplace, in my opinion, is to go in-ceiling speakers, or in-walls. Maybe even on-wall speakers, which they make some darn good ones these days but not very cheap.
lsi 9's -
I guess the trend started because a lot of fireplaces would traditionally have a mirror on the wall above them. And ladies could agree to replacing the mirror with a flat screen because it would not affect furniture placement elsewhere in the room. Also, the fireplace is usually the focal point in a room and placing a tv elsewhere is awkward.
If a flat screen above a fireplace is the only room option, a soundbar would be a better choice to get improved sound. -
Or, if he sits on axis while he watches TV, couldn't he use a "phantom center" by switching the center off in the menus?
We have friends who have their TV over their fireplace, and it actually looks nice, until you have to watch it.
In Florida, however, fireplaces are for the looks... no one ever actually uses them, AFAIK.
Thanks guys for all the feedback,
I was reading somewhere that 15 degree angle relative to your eyes is OK. That's about the case with my room. The room is huge and the wood burning fireplace in smack in the middle of the long-side wall. Putting it in a corner is not an option because it screws up the entire furniture layout. IMO if done properly (like, Samsung FrameTV with "modern" finish walls), it can look really nice. I can certainly angle it.
Just wondering if anyone has ever done something like this so I can see it. I think it will look out of place if it's just the speaker so probably need to run a shelf the entire length of the fireplace and fill it with some sort of decorations to blend the speaker in.
Wiring is also not a problem at all because I'd like to cover up the bricks so running wires is trivial.
I really don't want to sell my speakers and get something else. I really like them and of course I don't want to spend more $$. Plus, it's a cathedral ceiling so it's not that simple.
Yes, I know that they may not fill the room but it's certainly better than nothing (what I have now).
I will post pictures this weekend. -
I can tell you from experience, with a wood burning fireplace and a TV over it, or even next to it....your TV will be toast inside 2 years from the ash. I moved my TV to the opposite side of the room and still got ash inside. Winter time, my fireplace is going probably 5 days out of the week.
That's if you use it , if you never use the fireplace then rock on.HT SYSTEM-
lsi 9's -
I have a CS400i from the old house that was sitting on the mantel over the fireplace. Plasma TV was wall mounted above it. After a short period of time, the fireplace heat caused the vinyl to shrink and de-laminate from the front face of the cabinet. Now it's a project waiting to be fixed. Lessons learned.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
The horror stories on mounting a TV over the fireplace.
My bro lived in Seattle for a few years, Best place for the TV was over the gas fireplace. So he had pro's come and install everything with a nice in wall center speaker. Took two week and the center speaker melted. The installer replaced it and put a box around it. by spring the TV was done... He wound up moving the TV and everything to the opposite wall. In his new house they offered pre wiring for the fireplace mounted TV... Nope not again.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Easy fix. Strip that vinyl off (it’ll peel right off) and then take the bezel and speakers out and spray paint the front black (I just did the whole box). Whole thing took me about 30 minutes maybe...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Black paint? The hell you say... -
ken brydson wrote: »I have a CS400i from the old house that was sitting on the mantel over the fireplace. Plasma TV was wall mounted above it. After a short period of time, the fireplace heat caused the vinyl to shrink and de-laminate from the front face of the cabinet. Now it's a project waiting to be fixed. Lessons learned.
Where can I get black paint?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
It’s for the wood. -
I can hook you up for a price!!!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
I gots to pay for college for the kiddos somehow. At least I’m just selling paint!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
You are selling snake oil. Everybody knows black paint no longer exists.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Doesn't even look cool. Looks like k r a p, and is too high for decent viewing. Or even any type of viewing.
Three 20 amp circuits. -
Speaking of too high where ya been Bud?
Unless your in a bar. Who wants that kind of viewing at home though.HT SYSTEM-
lsi 9's -
Did you schmucks actually read his description of the room? Sometimes you just got to do the best with what you got. We've been casually perusing houses, and there are a number where mounting the TV above the fireplace is really the only viable option in the main living room. It't not ideal, but if its not too high and you can angle it as he says, its not the worst. If its super high, I would really try to figure something else out.
I will agree with others that if its a wood burning fireplace and the OP plans to use it regularly, then that will likely ruin the TV and/or speaker...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
My plasma that was mounted above the fireplace had a mount with an adjustable up/down angle. I was able to rotate it down enough so the viewing angle was good.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I've said this before. I don't like it myself, but I get that sometimes it's the only real option with a lot of floor plans. It's best in large, open floor plans, which are great, but often eliminate walls that would be better options, if they existed... A high mount is more acceptable at a greater viewing distance. -
Monoprice Above Fireplace Pull-Down Full-Motion Articulating TV Wall Mount Bracket For TVs 55in to 100in, Max Weight 154lbs, VESA Patterns Up to 800x400, Rotating , Height Adjustable
These things are ridiculous. Seems like a good idea, but not very practical, unless you watch a lot of TV and keep them down - where they look awful and possibly pose a hazard.
Also, a 100" TV on this thing? No freaking way!
