Setting up a subwoofer for 2.1?
  • FestYboy
    FestYboy Posts: 3,861
    la2vegas wrote: »
    mdaudioguy wrote: »
    la2vegas wrote: »
    mdaudioguy wrote: »
    I decided to get a new sub and shift the little Sunfire to HT-only duty. The more I listened, the more I noticed it just wasn't as musical as I had hoped. It has great output for its size, but only in what seems to be a narrow range. Since my hybrid system is biased towards 2-channel, the Sunfire gets demoted. Also, this will allow me to dedicate one sub to HT LFE duty.
    Next sub up for 2-channel... a Martin Logan Dynamo 700w. I've set several of these up for others and have always been impressed with this 10" down-firing sealed box. Since they've recently been discontinued, they're currently available at a ridiculous price.
    Although it comes wireless ready, I think the line inputs will be better for 2-channel performance. This sub seems like it should supplement my bookshelf speakers nicely.
    A couple of oddities - a non-stop bright blue flashing LED on the back when not connected wirelessly. Seriously, this thing doesn't give up. Also, it comes with spikes - that get inserted into the rubber feet. Yes, these spikes decouple! I'll use it this way for a while, but eventually, I think it will benefit from proper spiking.
    What's a good price on those Martin Logan subs on the used market? Maybe I'll follow your lead.
    Idk, but around $450 new online. Sold for $700-$800 in the past year. Some used on eBay under $300, but who knows what you get there.
    Thanks, I'll take a peek locally
    *Comes back 3 days later* Hey guys, look what I just picked up for $30...
  • mdaudioguy
    mdaudioguy Posts: 5,165
    FestYboy wrote: »
    la2vegas wrote: »
    mdaudioguy wrote: »
    la2vegas wrote: »
    mdaudioguy wrote: »
    $30???? Do tell.
  • mdaudioguy
    mdaudioguy wrote: »
    My integrated has pre-outs for subwoofer connection. At the moment, I just have a single RCA sub cable connected, but I'm thinking two would be better. Any suggestions for a PAIR of decent sub cables? Maybe 2 meters in the $100 range?
    Is two better though or does it not make a difference? I always wondered but just went with the flow.
    *Edit* I read that the preouts are usually set to output mono so it wouldn't make much of a difference, that is unless yours is different. Maybe the manual of the integrated would clarify.
    To be clear, these are not dedicated subwoofer outputs, like an AVR has, but true L&R pre-outs. So, yes, I'm shorting myself with just one cable. The sub is only getting the low end from one channel. I need two cables.
  • mdaudioguy
    And, it's pretty clear the little Sunfire is getting demoted again. It can't do HT justice, even in a hybrid rig where HT is priority #2. Our workout room has a TV with Polk in-walls that could use a little help. The only question is, another Dynamo 700, or its bigger brother, the 12" 1000?
  • FestYboy
    mdaudioguy wrote: »
    FestYboy wrote: »
    la2vegas wrote: »
    mdaudioguy wrote: »
    la2vegas wrote: »
    mdaudioguy wrote: »
    $30???? Do tell.
    Typical @la2vegas purchase
    Clipdat Posts: 12,557
    mdaudioguy wrote: »
    Surprised to see no toe-in on those speakers.
    F1nut Posts: 49,704
    I've got the fix for that.
  • mdaudioguy
    FestYboy wrote: »
    mdaudioguy wrote: »
    FestYboy wrote: »
    la2vegas wrote: »
    mdaudioguy wrote: »
    la2vegas wrote: »
    mdaudioguy wrote: »
    $30???? Do tell.
    Ah, gotcha! I didn't read the sarcasm, and was wondering where I might snag one for that, or what kind of condition it might be in, for that matter... :D
  • mdaudioguy
    Clipdat wrote: »
    mdaudioguy wrote: »
    I've only briefly experimented with toe-in, with missed results. There's an existing imaging issue with the right speaker being only one foot from the side wall, while the left is in a more open space. I have a couple of 2x2 acoustic panels I want to experiment with first, before I mess with positioning.
  • Willow
    Willow Posts: 10,862
    Why not build a small platform for the smaller sub and paint it black so it would blend in more making the two subs the same height.
  • Willow
    edited October 2018
    la2vegas wrote: »
    Willow wrote: »
    And where would you source this elusive black paint? :D
    Geez... it is and has always been available....... Right next to the unicorns!
