Polk Cs20 VS S35
I currently have a Polk CS20 Center . Would a Polk S35 be an upgrade or downgrade or the same? The rest of my set up are Polk TSi Series.
Thanks!
  • mlistens03
    mlistens03 Posts: 2,767
    I’d stick with the CS20, as it was designed to match your TSi speakers. It’ll sound a lot better than the S35 because it matches.
    Now, which is better? I don’t know. But, unless your planning to upgrade to the Signature series, I’d stick with the CS20.
  • the form factor of the S35 would help me as the large body of the current CS20 limits what I can do based on the height of my wall mounted TV and the entertainment center itself. I just don't want to downgrade audio quality. From things I see online it sounds like the S35 would be an upgrade but I've been shy to pull the trigger.
  • mlistens03
    I think that’s the S35 is a better all around speaker, but since the CS20 matches, it’d sound better.
    Now, it wouldn’t be too much of a difference, and if space is a concern, he S35 is probably the way to go. Either will certainly do fine. But if I had to choose one, it’d be the CS20, but I don’t have any space concerns so YMMV.
  • mlistens03
    Of course, with us being enablers here, we could find some way to tell you that you have to upgrade to the Signatures... then your performance could be maximized all around. ;)
  • codycatalist
    codycatalist Posts: 2,662
    What @mlistens03 is trying to say is that the sound won't be seamless from front left and right to center as the tweeter is different. There will be some localization of sound (you can pick out the center instead of one cohesive image). I say if you need it based on your set up and it would work better space wise just get it and try it. You won't see a high step up in SQ until you get to beefy centers and add some dedicated power.
    You might notice the difference but you might get used to it after a week or so. Buy it, don't like it after a week send it back.
  • mlistens03
    What mlistens03 is trying to say is that the sound won't be seamless from front left and right to center as the tweeter is different. There will be some localization of sound (you can pick out the center instead of one cohesive image). I say if you need it based on your set up and it would work better space wise just get it and try it. You won't see a high step up in SQ until you get to beefy centers and add some dedicated power.
    Thank you, you explained it much better than I did. :)
    VR3 Posts: 27,964
    Timbre matching is over rated. Ymmv
  • codycatalist
    VR3 wrote: »
    I've never been nitpicky enough with my HT to care so it's never been an issue for me. I'd say go for it.
    VR3 Posts: 27,964
    I don't think I've ever had a timbre matched ht, maybe when I first started, but quality speakers sound better than 5 matched lower quality speakers.... 😜
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited October 2018
    VR3 wrote: »
    Agreed. The OP should try the speaker he's thinking about. There's a fair chance he'll like what he hears. Three identical speakers sounds best. I can tell a difference. Even with timbre-matched speakers, traditional horizontal center speakers always sound a little off to me, particularly when playing test tones. However, if the difference is only noticeable then, who cares?
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2018
    I have never had matching speakers, and my system sounds fine to me. My center channel is a big Boston VR-920 speaker that is very clear, and with it being fed by an amplifier, I can hear all the music and dialog.
    I wouldn't change it out for anything except maybe a bigger matching Signature center channel. But since that isn't going to happen I'll keep my Boston speaker.
  • Gurm42
    Gurm42 Posts: 30
    There is a real difference, having matched speakers. I didn't think so, but I'm a convert to having a matched center. Unless you don't care about a single field of sound. If you don't mind knowing that the center is separate from the sides, then go for it. Or, just if you want to. LOL.
    Home Theater:
    Yamaha RX-V377 AVR
    Polk Monitor 70 Series II (Front)
    Polk Monitor 15C (Center)
    Polk Monitor 40 (Rear)
    Polk PSW-110 (Sub)
    LG 60" Plasma (6650)
    tonyb Posts: 32,902
    I've had both, matching center speakers, and different brands. Sometimes it works out for the better with different brands as the center, sometimes not. Depends on how much difference is in that tweeter in the center.
    Most of the time, you can get away with different Polk centers as their tweeters aren't too different....depending on the series anyway. For instance, the LSI centers won't gel well with the RTI or monitor series. Sig series should be ok with RTI, monitor, TSI series. Not a vastly huge difference.
    If you concerns are space, the S65 should work, but I don't see that big of savings in the size department. As for sound, I'd hit the S65 as the better speaker sound wise.
  • rooftop59
    rooftop59 Posts: 7,952
    +1 for mismatched centers, look at both my systems. My first priority is music, so I get the best LR speakers I can afford/find/will fit the space and SAF. Then I see if I can afford and fit the matching center. The answer is often no, I either don't wanna pay that much or it won't fit. So, I try something that is a good center and seems like it might be in the same tonal ballpark, and let calibration do its thing. Usually works out fine...
    Now, if you watch a lot of action movies or play a lot of immersive games, I don't doubt you might notice the difference. But I watch maybe 1-2 movies a month and don't play games, so for TV and netflix the closish matched center is fine for me...
    Game Room 5.1.4:
    Bedroom 2.1
  • Gurm42
    Gurm42 Posts: 30
    rooftop59 wrote: »
    I don't disagree. The Home Theater, however, is mostly for ... movies and games. And for that having a matched set of Monitor series (although they are from different gens) is more important to me than it might be to you. For music, I'm still futzing around with my secondary system. Looking for an older H/K head because I like the tone, and then pairing it with some serious 12-15" three-ways.
    Home Theater:
    Yamaha RX-V377 AVR
    Polk PSW-110 (Sub)
    VR3 Posts: 27,964
    I think as long as you use common sense, it would be hard to notice the difference.
    I wouldn't pair bose cubes with Polk lsim but brands that lean towards the brighter side or warmer side, etc paired together isn't a bad call
  • mrloren
    mrloren Posts: 2,454
    S35 will blend well with theTSI line. Use you're AVR calibration to blend it the best.
    I was using a TSX250C with my S60 till I got my CSi-A6. Both blend very good with my S60.
