Showcase your setups
  • scubalab
    scubalab Posts: 3,101
    Thanks Victor!
    It really is a shame that I haven't really spent a lot of time with this setup just yet. Heck, I've had the speakers from Jesse since June and the integrated from Ryan for at least 5-6 weeks. I've probably only spent a total of 1/2 hour listening before moving the setup into our guest bedroom yesterday. I spent about 45 minutes listening to some records and streamed music yesterday and was truly blown away. I can only imagine how much better it will sound when I get it set up in a more ideal configuration.
    Also forgot to list the Zu Audio Libtec speaker cables that are still burning in.
    Looking at some of the other systems in this thread... man, there are some absolutely beautiful setups some folks have!!
  • stangman67
    stangman67 Posts: 2,185
    scubalab wrote: »
    Not final yet and in a temporary location, but man, am I loving the 2-channel setup!
    Vincent SV-236MK integrated amp (from @ZLTFUL )
    Cambridge Audio 651P phono pre (from @Rick88 )
    Polk Audio RTA11 speakers (from @F1nut )
    Audio Technical AT-LP120-USB (purchased locally)
    5-shelf glass rack (from @stangman67 )
    Looking great Al! Bet that sounds fantastic
  • WLDock
    WLDock Posts: 3,073
    joecoulson wrote: »
    Side note that the AQ power change I just made seemed to center the bass more and seamless than before. Thank You for the thought though my man!
    No Problem. Good to hear that you figured it out. I'm my experience, the larger centers that I've used like the CS1000p, LSiM706c, and now my current Boston VR920 all helped in center anchoring of the bass. You hear it right away going from a smaller center to a larger one....provided the sub is already well integrated.
    2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2
  • motorhead43026
    Scuba, those pads isolate that TT pretty well? I know they do mine.
    And did they finally air out....lol.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
    txcoastal1 Posts: 13,132
    joecoulson wrote: »
    I’m confused
    So is Russ
  • scubalab
    LOL - yes, they did finally air out! I didn’t notice a huge difference, but they did help isolate the TT a little. The visible movement of the drivers is all but gone. They isolated the Audio Technical TT better than the Rega or the MCS. Good thing too since that’s the table that’s staying.
  • lightman1
    lightman1 Posts: 10,776
    ^^^Sweet! Gotta get back over there for some listening time. Rock on Victor!
  • halo
    halo Posts: 5,616
    lightman1 wrote: »
    You bet Russ!!
    DSkip wrote: »
    halo wrote: »
    1. Spikes.
    2. Toe them in.
    3. Grills off when listening.
    4. At some points I've also tried elevating the rear more than the front. Play with that and see if it improves.
    Thanks for the tips Skip!
    Can’t do spikes on the composite flooring and still be able to move them around. I’ll think about the spikes when I get them placed optimally.
    They are toed in. lol. I need to toe in the right a little more. Where do you recommend the tweeter placement? Directly at the ears? ? # of inches outside the ears? I have to buy a longer power cable so I can move the whole rack, and speakers, to the left.
    Ok on the grills off. :)
    I can try elevating the rear :)
  • halo
    halo Posts: 5,616
    DSkip wrote: »
    I liked them about 6" off axis from my ears. I also liked them more when my ears were level with the woofer.
    My ears sit a bit higher than most people when listening. I’m 6’ 3” and sit kinda high up in the wheelchair compared to an able bodied person sitting lower in a recliner or on a couch. ;)
    I will keep adjusting as best I can to get great results.
    These speakers look fantastic. The finish is smooth as glass. They had some smudges and spots on them when they got here but I used Über rinseless car wash, mixed with distilled water, applied with a Chemical Guys microfiber towel.
    Wondering if any of the past owners put a coat of auto wax on these? @vcwatkins @kharp1 Perhaps the original owner Craig got them from on eBay?
    I talked to Dave @daboyz and he just used a damp cloth.
  • kharp1
    kharp1 Posts: 3,453
    No. I never used anything other than a damp microfiber cloth. I did use a piece of gym floor mat as cushion for a 25lb hexagonal dumbbell placed on top of the speakers. I did this to determine if I wanted to order shot for the fill pockets. I did notice improvement by adding weight.
  • halo
    halo Posts: 5,616
    kharp1 wrote: »
    Thanks Kerry :)
  • Joey_V
    Joey_V Posts: 8,520
    Skip
    Are these the same as what I heard at your old place?
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
    audioluvr Posts: 5,434
    Kinda hokey compared to to others here but great ambiance.
  • Joey_V
    Joey_V Posts: 8,520
    DSkip wrote: »
    Joey_V wrote: »
    Skip
    I don't remember you hearing a pair of 6311, but these are the same ones I owned. You heard the Mini X.
    I heard those if you had them. I recall comparing them to the minix
  • marvda1
    marvda1 Posts: 4,873
    Joey_V wrote: »
    DSkip wrote: »
    Joey_V wrote: »
    Skip
    you heard the usher 6381's along with the mini dancer 2 at my house.
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
  • joecoulson
    joecoulson Posts: 4,943
    audioluvr wrote: »
    That an HD radio tuner in that rack?
  • vcwatkins
    vcwatkins Posts: 1,993
    halo wrote: »
    DSkip wrote: »
    I bought them used in South Carolina. Don't think the original owner did anything. I generally use a dry microfiber cloth. It's possible I used a bit of the Gibson guitar polish; not certain.
    My preferred placement was a bit wider than usual (probably close to an equilateral triangle) and toed in to a few degrees outside of direct line (a few feet behind listener's noggin). I did not try adjusting up/down and never got around to adding weight.
    Nice rig, enjoy!
    b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
  • halo
    halo Posts: 5,616
    vcwatkins wrote: »
    Nice rig, enjoy!
    I read through the thread when you bought them from the original owner on eBay with local pickup. Heck of a deal you got on these many moons ago :)
    la2vegas wrote: »
    That's a wonderful product, especially on the piano black found on the LSI lineup. m543ukmroi00.jpg
    Thanks for the heads up!
  • jonicont
    jonicont Posts: 277
    SDA 2BTL, VPI Prime, Soundsmith Zephyr MKIII, Rogue Ares Magnum, McCormack DNA 0.5 Gold, ARC LS-17se, Cambridge cxn v2, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
  • motorhead43026
    motorhead43026 Posts: 3,892
    edited October 2018
    Some of you guys take this shet way to serious.
    Some really nice rooms as well as setups.
    nooshinjohn Posts: 25,100
    @jonicont.... sorry, but I have to ask... who in their right mind hangs a cutout of a Mustang II on their wall? :p;)
  • jonicont
    jonicont Posts: 277
    😄😄😄😄 good eye! From a great song about racing called Daddy's Cup
    https://m.youtube.com/watch?v=McW2NwWtR9E
  • jonicont
    jonicont Posts: 277
    Custom piece from an artist named Ben Lamb. He does a lot of Rock and movie themed pieces. Also happens to be the bass player for Lydia Loveless. https://www.etsy.com/shop/3rdShiftDesigner/items
    That's the songwriter sitting in the car. It's 3 dimensional
    mhardy6647 Posts: 33,044
    edited October 2018
    EDIT: oops.
    Irrelevant, immaterial, inadmissible.
    (well, it was redundant, at any rate)
    :p
    sorry!
  • Joey_V
    Joey_V Posts: 8,520
    marvda1 wrote: »
    Joey_V wrote: »
    DSkip wrote: »
    Joey_V wrote: »
    Skip
    That’s right
    Viking64 Posts: 6,687
    EDIT: oops.
    :p
    sorry!
    Alright now you have piqued, peeked, and peaked my interest. It's not too, to, or two late to retype your, you're, and yore comment. There, their, they're is still time, thyme. Although the parsley, sage, and rosemary is in a different thread.
    Clipdat Posts: 12,604
    jonicont wrote: »
    15'x18' room
    What's driving the Focal bookies?
  • jonicont
    jonicont Posts: 277
    edited October 2018
    Clipdat wrote: »
    jonicont wrote: »
    15'x18' room
    some Yamaha av receiver. 100w/ch IIRC. going on 18 years. used it in the kids playroom
    pitdogg2 Posts: 24,578
    edited October 2018
    jonicont wrote: »
    and it's a Cobra......
