Not much action here so thought Id share a old school amp...
Yep2
Orion 250-HCCA.
Ive had this one a couple years.
Found it at a Pawnshop for $25!
I asked if it worked & the guy said everything is guaranteed.
Sure enough works perfect!
Only 100 Watts, this amp is BRUTAL on subs!
If Im not mistaken it will put out 1100 watts @ 1/2 Ω stereo!
Built to Military Specs, It sounds fantastic to my ears fullrange (one of the best Ive ever heard), but have read some disappointed reviews running it fullrange.
No processing, no x-over built in, its pure power.
Dont see many of these anymore.
mhardy6647 wrote: »I didn't realize that the military had specs for car amps. Cool.
And fuschia, too? Even better. I was expecting olive drab or desert tan, for some reason.
(OK, I'll move along now)
That's part of the new military, you know, don't ask don't tell. -
I worked at a car audio shop in high school. When those amplifiers came out, they ruled the competitions. I don't know if they are just extremely underrated on the power or what, but that particular amp is 50 Watts a channel and was outperforming 500 watt amplifiers at that time (88-90)The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects -
Quality watts rules all- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Cool. I've thought about putting a decent system in my 59 Bel Air.
So far it's only got a facsimile (AM/FM/Aux) head unit, replacing the original AM tube radio (which worked), and the single 6x9 speaker was replaced with a 2 channel coaxial speaker.
I stream to it via a BT Dongle connected to the AUX jack. That's about it.
Resisting the temptation.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I believe that 100 was for both channels. it was a competition amplifier, so if I remember correctly, they raided total watts, and not per Channel. It was considered a 50x2. The first one I remember was actually a 425. Four channels, 25 watts a channel. I made a mistake and on that particular amp, but I believe that is actually how Orion did their model numbers at that timeThe difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
Belittlement is not your strong suit Mark...
Yeah, I realized that -- I thought I was being witty, but realized I was just being snarky, and so I blasted the post; just not quickly enough
ahh, well...
So... a question about an amplifier like this one. How to they get the DC rail voltages high enough to get that kind of output power? Do they use an inverter to generate AC and then a switch-mode power supply, or something like that?
I don't know anything about car audio (obviously!).
Seems like 25 dollars well spent.
Jay
Be careful you'll make his leg twitch then someone will be cleaning up.
It was mutual assured ribbing, fear not all y'all!
I did find an interesting rehab thread for one of these amps -- thing is chockablock with FET outputs.
https://www.stevemeadedesigns.com/board/topic/201683-refurbing-an-old-school-classic-orion-250-hcca-x2/
I missed something
I'm sorry if my post wasn't clear -- I meant that the innards of this amplifier, based on the photos in that thread, were impressive, with a tonne of output FETs. My earlier comment wasn't meant negatively at all!
It's easy to understand how the power (watts) is generated when you see the current draw... Upwards of 300A!! Just like Jesse likes to preach (and rightly so), that high current amps are where it's at. -
My apologies.
The link was of interest to me because of the photographs. I didn't see it as a review.
I am sorry; lesson learned.
Feel free to set me to ignore; I do undersand.
