Power
Justinthomas1977
in Speakers
I have polk monitor 75t speakers they say 20 to 275 watts... I running 120 watts to each on my hk 3490.. My? Is will they play louder and sound better if I use a pa audio amp 300 rms to each
Best Answers
afterburnt wrote: »"all shut eyes aint sleep and all goodbyes aint gone"
Good to have you back Bruce -
Guys, your wasting your time. He doesn't care about sound quality, so what's the point of continuing. Get pro stuff and bleed your ears out dude. Done also.HT SYSTEM-
lsi 9's -
YepBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I still think this thread can be fun, so here is a donkey in a boat.
Mad power and an equal amount of sound quality. There was a small amount of buzz about this amp on some Home Audio boards. Some people said such an inexpensive amp just couldn't sound good and had no place in a Home Audio rig. Funny thing is, this was said by people who hadn't heard it. Those who heard it in their systems were amazed at what they heard. Even more impressive is that it delivers sonic performace rivaling that of MUCH more expensive audiophile amps. I'm driving a pair of Magnepans which are VERY revealing speakers and they reveal this amp to be wonderfully powerful and transparent.
The bass is clean, tight and powerfull. The mids are totally transparent. The highs are very detailed, clear and extended. Whatever your source supplies, it will be faithfully passed on to your speakers. I've been an audio enthusiast for over thirty-five years and these ears know good sound when they hear it. Detail, dynamics and headroom. This amp has these by the boat load. Listen for any sonic warts or shortcommings and you won't hear any. Often, high end speakers present difficult loads, have low sensitivity or just plain don't sound good unless driven by a powerfull amp with plenty of headroom. Usually these amps are very expensive. With a EP1500, you can drive these speakers without going broke to do so. If you're going to seperates for a music system or bypassing your HT receiver's onboard amps to get big power, this is your ticket. A big, high quality SS amp just makes speakers play better! -
Lol OK bye I'm leaving
You copied that post from Audio Review, it's one of two reviews......LOLPolitical Correctness'.........defined
President of Club Polk -
How but this.. Is it Better then my 120 wpc hk 3490 receiver
Justinthomas1977 wrote: »I can't tell diff frm a sony receiver frm a marantz or onkyo
It's in the spelling.....
I keep seeing comments on the second page of this thread, then they disappear. Vanilla is open source software and it needs someone to babysit it. Is there even a webmaster here?
It all fooed up
Something is messed up. The OP has somehow managed to mark 3 of his own posts "accepted answer".....lolPolitical Correctness'.........defined
I would refer you to the last quote on my signature...because I have been there too. I mean not this argumentative but I have been there.
Like I said Justin, look at eBay to save some (a lot) of money on the 545...
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/223159318137
I'm in Canada your dollar is diff then shipping I think 300 is cheap
Answers
They’ll sound better on the H&K, but not because of the power rating. The H&K is a better amp, designed for sound quality, whereas the pro amp is designed to be able to take lots of abuse, such as running at 100% power for extended periods of time.
Take this advice from a guy who bought a pro amp, and is now stuck with it. -
The higher number of watts is less a factor than the quality of watts, and amps (current) even more so. Most PA amps sacrifice sound quality for ability to provide volume in larger rooms (venues as apposed to home listening).
Justinthomas1977 wrote: »I have polk monitor 75t speakers they say 20 to 275 watts... I running 120 watts to each on my hk 3490.. My? Is will they play louder and sound better if I use a pa audio amp 300 rms to each
NoPolitical Correctness'.........defined
Short, sweet, to the point, and correct. LOL.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
These speakers will clip and blow tweets when I put up vol to high so I thought more power will solve this -
mlistens03 wrote: »They’ll sound better on the H&K, but not because of the power rating. The H&K is a better amp, designed for sound quality, whereas the pro amp is designed to be able to take lots of abuse, such as running at 100% power for extended periods of time.
How much more crappy did they sound..? And how bout 300w to each with home amp but they wayyyyy more money -
Justinthomas1977 wrote: »These speakers will clip and blow tweets when I put up vol to high so I thought more power will solve this
Well, that's another question altogether. The answer is likely "yes" that this might solve clipping issues. Will it play LOUDER? Most likely. Will it sound BETTER? Very unlikely.
Loud. Good sound. Inexpensive. Pick 2 of the 3. -
LOL......junkPolitical Correctness'.........defined
Justinthomas1977 wrote: »The higher number of watts is less a factor than the quality of watts, and amps (current) even more so. Most PA amps sacrifice sound quality for ability to provide volume in larger rooms (venues as apposed to home listening).
First lesson, all watts are not created equal.
Second lesson, to increase the volume level by 3dB it takes twice the power. Going from your 120wpc amp to a 300wpc amp will gain you roughly 3.5dB.
Third lesson, one can make just about any amp clip by turning up the volume too far.
Fourth lesson, a cheap amp gets you bad sound.
Fifth lesson, a good amp costs money.Political Correctness'.........defined
6th lesson....if you like it louder, you bought the wrong speakers. Buy speakers that can handle that loudness like PA speakers, Crappier sound, but they'll go louder.
7th lesson....everything has it's limits. Turn the volume knob down if you don't want to keep blowing tweets.
8th lesson....those "recommended watts" on the back of speakers mean little.
9th lesson....get your read on and learn about audio. More to it than just buying a pair of speakers and cranking on the volume knob.HT SYSTEM-
lsi 9's -
10th lesson, take heed to the advice here. I did, but must admit took a lot longer than 24hours to get 9 lessons! You must be in the condensed course!
Welcome Justin! Hang around, lots of good advice here, and information.
My tenure here on CP has been very informative, and fun!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
If you want loud, get Cerwin Vega. About all they are good for is going very loud.
Now if you want sound quality please listen to these people.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
I'm done here. And I no all this stuff ppl are telling me I been in home and car audio long time I just have never heard pro audio stuff ever in home audio.. And this a polk audio forum polk ain't that great of a speaker I bought for the cheap price.. In other high quality forms ppl say some of the pro stuff sounds good... I'm looking for clean and loud I don't care about Sq hell I think cerwin Vegas sound good any ways thx I'm finished here
Oh and I sold my klipsch rf82s I miss those they got loud and had high sensitivity only sold cuz they got all banged up
The scary thing is that he walks among us. There should be an IQ test given before someone can join here.Political Correctness'.........defined
He plays a good game of golf though, have to give credit where it's due
Seriously though, stick around, it's not that bad here and you can get some really solid
advice. NO ONE will intentionally steer you wrong.
http://audiomilitia.proboards.com/ -
Just because they tell you what you don't want to hear, doesn't mean it's wrong. There are some people here who know a lot about audio.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables.
Will this rotel 70wpc be a down grade from my hk 3490 120wpc louder sound better?
Rotel makes very good amps. All things being equal at the very least it will be equal to the HK since the only job that the Rotel has to do is power your speakers. Go for it.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
But, but... then y'all wouldn't have me...
umm...
wait...
OK, I see your point.
My Teen setup was 15" Cerwin Vega (D9 I think) and Polk bookshelf speakers. When I wanted it loud I used the Vegas, when I wanted SQ I used the Polks.
Car audio to home audio is a a lot different. Cars are small compared to homes. A lot more space to fill in a home.
A receiver has a lot to task the power supply with. As in car audio you get better cleaner power from a separate amp.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Wow ppl on forms got lit of time on there hands... I can't tell diff frm a sony receiver frm a marantz or onkyo
Sounds like a personal problem.Lumin X1 file player, Westminster Labs interconnect cable
Justinthomas1977 wrote: »Wow ppl on forms got lit of time on there hands... I can't tell diff frm a sony receiver frm a marantz or onkyo
Oh dear. -
Justin Justin Justin. Listen and learn. Nice and easy. Don’t try and go toe to toe with these guys, they really know what they’re talking about. I’m a testimony to their tutelage. Come in with open mindedness, not fists clenched and swinging. Read my threads. You too can take a similar journey.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
