Hockey Pucks!
Getting sticker shock on the price of subwoofer risers, I ended up buying a dozen hockey pucks for $18. Need ti get it up off carpet and should work fine.
  • Don Rickles approved !
    Garage | Polk Monitor 5B's
  • FTGV
    FTGV Posts: 3,649
    edited September 2018
    deronb1 wrote: »
    Were they made in Canada or the Czech Republic ? There are some subtle sonic differences between them.
    nooshinjohn Posts: 25,034
    Russian hockey pucks tend to be the preferred combination of density and polymer blend, particularly at the sub-atomic level, where micro-acoustic properties come into play. The ones found at Chernobyl tend to put off unwanted sonic artifacts however, such as increased background noise.
    mhardy6647 Posts: 32,926
    ahem -- in our abode, of course, vintage pucks are de rigueur.
    B)
    In seriousness, I am a big fan.
    These are good, too, for the $ and FWIW. Available in various sizes and thicknesses.
    If one is feeling a tad insecure vis-a-vis one's audiophile cred, they're also available with slightly different cosmetics as audio products at a much higher price. :|
    https://www.amazon.com/Diversitech-MP4-V-Anti-Vibration-Pack/dp/B00BVEMLR4/ref=sr_1_5?ie=UTF8&qid=1537887145&sr=8-5&keywords=diversitech+pads
    I know folks with turntables more valuable than my car (actually, probably more valuable than all of our cars put together) that use 'em as opposed to the name brand
    In my more febrile moments :# I wonder whether Rockler's Bench Cookies have any application in hifi...
    https://www.thewoodwhisperer.com/articles/bench-cookies-yes-please/
    https://www.rockler.com/search/go?w=bench+cookies&view=grid
  • deronb1
    deronb1 Posts: 5,021
    I will expound on the hockey puck / subwoofer symbiotic benefits at a later date :)
    Tony M Posts: 11,009
    https://www.rockler.com/search/go?w=bench+cookies&view=grid[/quote]
    I bought some of these and gave some of them to an old friend to use as risers. I didn't buy them for vibration control at all, just for risers.
    They come in "Black" just for the home user. That's the color I bought. They were on sale too. :)B)
    deronb1 wrote: »
    gonna hold you to that commitment...
  • deronb1
    deronb1 wrote: »
    Great! Another deadline..... :smile:
    deronb1 wrote: »
    deronb1 wrote: »
    I only do thermodynamics, not kinetics.
    Y'all should know that by now.
  • deronb1
    Well, im gussing the pucks will have almost zero potential energy with a 60 lb sub sitting on them on a slab :wink:
  • In Canada you can buy a sub woofer that looks like the Stanley Cup... OK maybe not...
    pitdogg2 Posts: 24,481
    deronb1 wrote: »
    Well, im zero potential energy :wink:
    And there's your new anti energy drink.
    B)B)
    SCompRacer Posts: 8,350
    I am offended by the word puck, though I use one similar frequently. :D
    What a puckish thing to say B)
    SO, while your setting Canadian or Czech pucks under your gear, are you pucking around for sound? :D
  • deronb1
    deronb1 wrote: »
    B)B)
    That might kill me
  • deronb1
    Ok, first of all, the pucks smelled great! Never smelled a freshly minted hockey puck before. Second, got the sub about an inch up off the carpet and tightened things up a bit. Well, that's about it.
  • The scent of hockey pucks being pleasurable or not is relative to the velocity at which it makes contact with your nose.... Talking from experience here....
    That explains that mug you sport B)
    Resisting the temptation to butcher an Apocalypse Now quotation in service of this thread.
    You hockey pucks, you!
    Hockey pucks are incredibly useful. I keep a box of them for gunsmithing duties
    that's a big bore barrel.
    go big or go home Doc. LOL
    like a punt gun :|
  • deronb1
    deronb1 wrote: »
    I don’t think I have ever read a more thought provoking and in depth review of anything ever in my lifetime. I found your comment about the aroma emitted by the pucks to be insightful and pertinent to moving the review forward and compelling enough to pull me in and inspire reading even further. Your methodology for raising the subwoofer just one inch was brilliantly thought out.
    You had me hanging on every word as you disclosed your findings of things being “tightened up”... wow!! And not be too much either. Just a bit.... more brilliance!
    I think I need a cigarette and some towelettes....
    Im glad you found it inspiring and an enjoyable read...lol
  • FTGV
    FTGV Posts: 3,649
    I use the ones I find with Toronto Maple leaf logo's for target practice.
    FTGV wrote: »
    I knew there was a reason I liked you!
    Drill small and different sized holes through them and drive roll and other pins out and capture at the same time.
    Route a V-knotch across to hold small heavy "pipe" like things as well.
    Route 1/2 round in two use them to clamp things in a vice
    A thick heavy durable substrate to pound on and non marring as well.
