Additional garage at Verb's house!
verb
verb Posts: 10,176
edited September 2018 in The Clubhouse
Among my many projects throughout the house over the past year, I have been working on expanding my garage capability on property. We currently have a 2.5 car garage. We have about 2 acres of property, and part of the allure of this home was the tentative approval from the association board of directors to allow more garage space.
Here is a concept sketch of our proposal:
We've hired an architectural company to do all the renderings, plans, site analysis, local governmental analysis, yada yada.
First step is I have to present our proposal to the Board of Directors. Wish me luck! :smile:
«13456710
  • DaveHo
    DaveHo Posts: 3,480
    Is that a separate structure or an addition?
  • verb
    verb Posts: 10,176
    We have 2 proposals. One is an addition, the other is a completely detached at the back of our property. Currently the by-laws only allow "attached" garages, but our ultimate would be to have the detached as shown.
  • DaveHo
    DaveHo Posts: 3,480
    With 2 acres, detached is the way to go. Not a fan of homes where the garage is the first thing you notice.
  • GlennDog
    GlennDog Posts: 3,085
    NICE!
    Good luck, Bro!
    Source Lumin U1 Mini into Lampi Baltic 4
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • verb
    verb Posts: 10,176
    DaveHo wrote: »
    Yep. Our existing garage door is at a 90 degree angle to the street.
  • FestYboy
    FestYboy Posts: 3,861
    This a perfect reason why HOAs blow things I can't mention here. I don't have to ask permission to do anything on my property, and neither should you.
  • verb
    verb Posts: 10,176
    It's a choice Festivus! I knew that going in, in fact we had met the board prior to the purchase of the house. They seemed warm to it, so we bought the home. I've already had pre conversations with most of the members, grease the skids, you know the drill.
  • kharp1
    kharp1 Posts: 3,453
    Hopefully you can change their mind. HOA's can be real PITA's.
  • verb
    verb Posts: 10,176
    kharp1 wrote: »
    Yep. At the old house they were a bunch of ****'s. I eventually became a member, and then president. We changed a lot of the by-laws to make it more friendly. The older members eventually quit because they were over-ruled too many times.
  • Airplay355
    Airplay355 Posts: 4,298
    They aren’t always bad...like when someone decides to rent the house next you to a frat or when a backyard becomes a car junkyard. Just situations I’ve dealt with but we don’t have an HOA.
    I’ve got one of those houses where he garage is the first thing you notice but on .5 acre and my first house, it’s enough for me :)
    Your new garage looks like it will be awesome! What kind of cars are going in there? Assuming it’s approved of course ;)
  • Milito
    Milito Posts: 1,909
    A man can never have too big a garage or too many tools.
    Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables.
  • verb
    verb Posts: 10,176
    I’ve got a 59 Chevy Belair, 04 Chevy SSR for the Mrs, and 2 Harley’s (03 Heritage and a 99 Sportster). Plus the usual amount tool chests (3), woodworking tools, lawn tractor with trailer, etc. Lots of stuff!
  • Milito
    Milito Posts: 1,909
    Yea you need more room.
  • Milito wrote: »
    You need more stuff
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    treitz3 Posts: 18,305
    One thing you may want to entertain is having a separate landscaping shop built right on the back of the garage. We have one and it is nice to keep garage stuff in the garage and nothing but landscaping stuff is its own area.
    The only time my tractor goes into the garage is when I want to work on it. Food for thought. BTW, a 10x16 shop for landscaping can get filled up quick for a 2 acre yard. FWIW.
  • verb
    verb Posts: 10,176
    Yep. Good idea. Keep all the dirty stuff separated.
  • verb
    verb Posts: 10,176
    Milito wrote: »
    You need more stuff
    I’ll have room for a 3rd toy car!
  • verb wrote: »
    Milito wrote: »
    You need more stuff
    Sweet! 59' Eldorado Biarritz Convertible with a tri-carb and factory buckets
  • verb
    verb Posts: 10,176
    Below are the 2 proposals for the garage. First option is the ultimate, what we want, detached. Option 2 is the fallback proposal if they insist on it being attached. To make the 2nd option "attached" we'd have to build a breezeway between the 2 buildings.
  • verb
    verb Posts: 10,176
    verb wrote: »
    Milito wrote: »
    You need more stuff
    Yeah baby - she would fit!
    Detached but attached with a drive through with additional storage? Optimum.
    I do not see what they see but I see much larger and (more common sense) space given the yard. TBT (and I know full well you are limited).
    Closer is always better..........(notice the periods) given the space to have vehicles move around one another or shuffle things around without driving over one's lawn.
    Which may be inundated with moisture. Your call.
    I report from experience. You decide.
  • verb
    verb Posts: 10,176
    Yep. Exactly the discussion I had with the Mrs. she prefers the closer option.
    tonyb Posts: 32,906
    verb wrote: »
    How much extra for the chick on the bottom right with the nice legs ? :)
    Looks nice man.
    Tony M Posts: 11,013
    I love the proposal diagrams!
    I took mechanical drawing in high school and LOVED drawing overhead views. The person or Company who you hired is definitely a 1st. CLASS drawing and designing presenter.
    Cudos!! ;)
    I like the one where the extra garage is further away. It gives you more access to your back yard.
    But putting in the back corner takes away from your "yard's park-like look".
    That brings me to liking the closer one also to keep your back yard wide open.
    Either way, a swimming pool will fit nicely behind your home. :):p
    Viking64 Posts: 6,677
    The house will look more substantial from a curb appeal aspect with the garage closer. Too bad that 10' setback is so close to the bottom corner of the garage. Otherwise you could build a pretty porte cochère between the main structure and the detached garage.
    https://www.google.com/search?gs_ivs=1&q=Porte+cochere
  • verb
    verb Posts: 10,176
    Yep that was our original thought. We were a bit surprised once the detailed survey came in.
  • BMF35
    BMF35 Posts: 86
    Don't forget a couple of drains in the floor.
  • verb
    verb Posts: 10,176
    So last week I presented the proposals for the garage. Both attached (allowed), and detached (not allowed). Well I'm happy to report that both proposals were approved! They agreed to waive the "detached" constraint in our case. We can do either!
    So now the Mrs and I are in negotiations, ahem, discussions, about which one to choose. Either way, a new garage is coming! :smile:
  • verb wrote: »
    With new SRS's in your possession, I'd say the Mrs. will get the final say on the garage location :D
