What Center Channel to Match Monitor 40
I am about to purchase Monitor 40 speakers for my front speakers and my rear speakers.
Which center channel would be best to match these speakers?
Which subwoofer would be best to match these speakers?
Thank you!
Thank you!
Answers
I think the Polk Audio CS10 center channel, would work just fine.
And for a subwoofer I don't know your budget, but if you can afford it, I would recommend you to buy an svs subwoofer. And if you have a tighter budget I would recommend the Polk Psw10, or the Polk HTS SUB10.
2 Channel:
Jbl Lx44
Optonica Sa 5105
Blue Jean 12 gauge cable
Audioquest evergreen 3.5mm to rca cable
Technics Sl BD22 TT
Randomness:
Klh model 26's
Peavey Pr15's
Gls cables for peaveys
Numark DM1175 Preamp mixer
Random cables
Bic f12
Svs soundpath subwoofer cable
Lafayette Lr-200a amplifier -
CS10 will be... fine. But it was intended to match a slightly different set of speakers. CS1 is the model that was intended to go with the Monitor Series II 30/40/50. CS2 was intended for the Monitor Series II 60/70. I personally went with the Monitor 15C, which is the remake of the CS1, because it matched better than the CS10. That said, you won't see a HUGE difference on the CS10, it's just made from different materials.Home Theater:
Yamaha RX-V377 AVR
Polk Monitor 70 Series II (Front)
Polk Monitor 15C (Center)
Polk Monitor 40 (Rear)
Polk PSW-110 (Sub)
LG 60" Plasma (6650)
