Post a picture... any picture
Yet another visitor.
I was bending down about 6" away when I saw him and let out a man scream.
Now he has a severe headache.
Shudders!!!
I think that snakes are pretty when you see them in pictures, or in a cage... now when they are slithering past you,that's a different story.
You don't see these Dayens Ampino Monoblocks come up for sale too often:
Seen here: http://www.hifi-intouch.co.uk/products/3329/21/transistor-power-amplifiers/dayens-ampino-mono-power-amplifiers.aspx
I like the description, sums up their performance nicely:
"HiFi In Touch are now dealers and stockist of the stunning range of amplifiers from DAYENS. These amplifiers are very special and can compete with far more costly alternatives.
Very smooth and valve like sounding, powerful, transparent, dynamic and most importantly very musical.
Not heard of DAYENS and are sceptical that these amplifiers are as good as we claim they are? Ask about our no obligation home demonstration." -
LG OLED 65C6 - Denon AVR-x3400 - Emotiva A-5175 - OPPO 203 - Polk RTI A5 towers, CSi A6 center, FXi A6 surrounds - SVS PC12 Plus -
My ugly mug in Exuma,Bahamas back in May. I sure do miss that place! -
Way to ruin a perfectly good nature shot -
I'm digging the shoes Charley. -
If ya zoom in, I think that's Russ and Ryan in the water back there. lolHT SYSTEM-
lsi 9's -
Good times, Tony! You shoulda been there. -
I bet I could out ugly you..... -
Mini dinosaur!
I prefer the Panasonic model with tube:
Tubes in a car doesn't seem like a good idea to me... although I'm not sure why i don't think it's brilliant. Either way, both look stellar!
Car radios had tubes in 'em into the 1960s. A whole line of low-voltage "space charge" tubes was developed very late in the tube era, specifically because cost-effective high-frequency transistors lagged audio-frequency transistors in availablity to the consumer electronics industry by ca. a decade.
Until the late 1950s/early 1960s, car radios used fairly normal tubes, requiring relatively high plate voltages -- the power supplies for those radios were clunky affairs using an electromechanical gizmo called a vibrator (get your minds outta the gutter! ) to generate dirty AC (EDIT: actually, pulsed DC) that could then be used with a fairly normal "linear" (as we'd say nowadays) transformer/filter type HV power supply to generate the voltages needed by all-tube car radios well into the 1950s.
Scan_Pic0034 by Mark Hardy, on Flickr
The space charge tubes required only the 12-ish volt DC available in a car to operate. These tubes bridged the gap between all tube and all solid state auto electronics.
Today, these odd little tubes are easy to find and cheap, which has led to a certain amount of interest in using them for... well.. whatever nefarious purposes folks can dream up.
http://www.junkbox.com/electronics/lowvoltagetubes.shtml
Pete Millett designed and a DIY'able hybrid headphone amp/linestage using space charge tubes. I've built a couple of these (his original design, as published in audioXpress) over the years; tonnes of fun they are, too.
http://www.pmillett.com/hybrid_head.htm
realhifiglows by Mark Hardy, on Flickr
PS I remember that Panasonic car hifi -- never saw/heard one, though. There is a company specializing in auto tube audio, FWIW: http://milbert.com/
The sum total of my knowledge of 'em is that they exist.
Back in the days of yore when I worked at a store that installed car audio gear there was a vacuum tube car amp available. I can't remember the company's name at present.
Pretty sure that the car rekkid playas that celebrities as disparate as Lawrence Welk and Muhammad Ali were rockin' back in the day used tubes, too!
Just in case any of all y'all young whippersnappers thought that your generation invented distracted driving!
Wow, I didn't know that! Very interesting. I guess I should've thought about what they would've done before SS amplifiers were invented.
Thanks for sharing!
Real quick question, did they ever use shock absorbers for housing the tubes, so they didn't get damaged by being bounced around every which way? -
Would they need them? I thought tubes were designed to be used in missiles, etc.
WHAT!?! I didn't know that!
I guess I always thought of them as fragile things. The kind of thing that would crack with only minor impact. -
mlistens03 wrote: »Wow, I didn't know that! Very interesting. I guess I should've thought about what they would've done before SS amplifiers were invented.
Thanks for sharing!
They used tubes in missles * and hydrogen bombs. They're actually pretty tough.
In fact, no, there weren't generally any special considerations made for radio tubes in cars -- though shielding them from static generated by the engine ignition system was pretty important
_________________
* In fairness, the tubes used in really harsh environments were typically ruggedized versions of the ones we all know and love. In fact, some of them are highly sought after (i.e., expen$ive) today for hifi use. Imagine that?!
source: http://www.itishifi.com/search?q=RCA+red
actually, the true "guided missle tubes" were typically made by folks like Bendix
http://www.timeelect.com/vacuum-tubes-tc-myths-and-snake-oil-marketing.html
Keeping on subject, here is a photograph of actor William Bendix. (Probably wearing TUBE socks, too.)
Interesting, seems to imply that a different "hardened" glass was used in the Bendix tubes.
500G max impact shock!?! Holy hubcaps Batman!
I don't think that'll break if you drop it.
And to think, I thought that setting it down on the table too hard would crack it! -
I ran a pair of Westinghouse branded 5962s in the "Simple 2A3" amp for quite a while. Not sure that they sounded better than (ahem) lesser 6SN7s, but they sho'nuff do look cooler.
Westies closeup by Mark Hardy, on Flickr
I've since gone (back) to higher-mu voltage amplifier tubes (6SL7 -- for which the amp was designed!), and, unfortunately, I don't have a pair of "Special Red" 5961s to use in it!
EDIT: meh, I'd have to add a separate filament transformer to handle 5961s in the amp -- I forgot
Post edited by mhardy6647 on
