Polk Audio CRS + (RDO198) Crossover Modification Thread
  • ptrooperptrooper Posts: 236
    Thank you Dave, The dread naught is perfect
  • westmassguywestmassguy Posts: 6,070
    ptrooper wrote: »
    Was my pleasure
    Home Theater/2 Channel:
    Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
    Interconnect: Furez 10/2 with SpeakONs
    ICs: Custom Furez by Douglas Connections
    Den:
    Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
    Carver CT-3 Pre, Carver C-500
    dhsspeakerservice.com/
    Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
    "And keep her under 70, would you, huh? Betty likes a slow ride"
    I contemplated only cutting holes for the internal connections leaving finger room to unclip but by the time i did the drawing template i really didnt cut out that much more than what was needed.
    I have had drammas with overlapping materials with my SRS and more seals or glue would have most likely been needed between them.
    The plates that the crossovers are attached too are extremely solid and well braced .I added a little dynomatt internally where possible(3 square "s max ech".
    It reminds me of the SDA SRS-1.2 plate.
    I wouldn't add braces to the front bezel but if it was originally braced i would definately check and add extra glue,re glueing my braces and Larry's rings in my 2 X SRS'S in my theatre lowered my noise floor and added more depth and air.
    SDA CRS 4.1 TL 20 hrs in and they sound amazing.
    edited August 6
    500 hrs and counting down
    Post edited by ptrooper on
  • Mike ReeterMike Reeter Posts: 3,255
    Extremely nice work by everybody involved in this Awesome Project, wish I could have a seat in the Sweet Spot!
    SDA SRS 3.1TL's/SDA CRS+4.1TL's and some other stuff
    I highly recommend Dave and Trey's handy work and lets not forget of all the shared knowledge through this great site which i have been stalking for many moons now.
    what can i say.......24 hrs playing and triple wowsa ,i am so surprised ,these little monsters are already surpassing my expectations ..... <3
    burn in with a little sunfire 17" 5 x 225 channel, mitt cvt terminator 1's to current top end and voltage to lower end via transparent reference mm fed by a little sonos connect ,i guees i should hit 500 hrs in 20 more days :p then oppo105D modded by Mr Joe Rasmussen takes over dac duty .
    ohhh,i forgot to also thank Larry,who within a nites notice supplied the last remaining set of rings he had for my CRS when i asked in the forum around 7 months ago.
    Thank you Larry ,i would never build a set of polks with out your rings, these put them up on another level instantly!
    cheers Mate
  • VR3VR3 Posts: 22,079
    Glad to hear they are opening up nicely.
    Ive been very impressed with the cmr... Same level of detail of the Mr but a hint warmer
    Vr3Mods.com ///// Version3Audio.com
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
  • Toolfan66Toolfan66 Posts: 13,786
    I have to say that was a ballsy mod cutting that hole in the cabinets, they look awesome, and there is no copyright on my speaker stands, or rings for that matter, if one has the means to build them, build them!! I’m not one to get butt hurt because someone copied an idea, it’s a hobby, and these speakers are how old? 30 years?
    The stands look great, along with the crossovers, I love the braided speaker cables..
    Enjoy..
    Thanks mate, all fun , It was just some harmless banta and Your absolutely correct ,It was a hard decision cutting them out , im glad I did they were a little Fidely installing the washers ,nut and locking nut ,not much room within these little babies but I can certainly say they gained a little weight
    Sean did a great job on the install.
    Larry if your comment is towards me, feel free to PM me.
    VR3 wrote: »
    It was not directed to you, but looking at it I can see why it came across that way, my apologies..
    That hatchet was buried a long time ago, well I would like to think so.. :#
    edited August 8
    Yep thought so to lol
    love the pic
    Toolfan66 wrote: »
    Enjoy..
    in case any one is wondering...the circles are the bare minimum needed to have installed thesee7kwcbalwb35.jpg
    xovers
    Those bad boys do take some. Real estate
    They sound incredible thanks Trey....I'd do it all over again no problem!
  • xschopxschop Posts: 830
    Try flipping the passive if you think you may have lost a some internal volume with your new mods.
    350 hours and all positive , cheers. Thanks for the tip
Howdy, Stranger!
