Third times a charm?
Gots a new thing in pieces!
So far...
Aaron
Enabler Extraordinaire
    heiney9 Posts: 25,079
    Cool! Keep me in mind if selling eventually becomes an option. I passed on the first 2 offerings. Now I'm on a waiting list.
    Anxious to see the build progress
    pitdogg2 Posts: 24,559
    msg Posts: 9,430
    Looks like fun!
    Which model did you go with?
  • ALL212
    ALL212 Posts: 1,556
    Silver stereo.
    Blake - I’ll keep you looped in and you’re #1 on the list,
    Another step done.
    Aaron
    mhardy6647 Posts: 33,029
    pieces.
    are.
    good.
  • mlistens03
    mlistens03 Posts: 2,767
    pieces.
    are.
    good.
    Not when its my gear. For me, pieces means that it may never be assembled correctly ever again. :tongue:
    mlistens03 wrote: »
    pieces.
    are.
    good.
    You are young, young Jedi. Experience, it will come.
    Yoda Trioda
  • ALL212
    ALL212 Posts: 1,556
    Lol... Blake... Brock...
    I’m a moron..
    Aaron
  • ALL212
    ALL212 Posts: 1,556
    Tonight’s progress. Directions for this are terrible, doable, but terrible.
    Aaron
    I knew who you meant. Looking good!
    Directions?! Ever see the Venn diagram describing men and directions?
    There is no intersection.
  • ALL212
    ALL212 Posts: 1,556
    Directions:
    Step 1:
    I don't mind that you have to figure out where the proper resistors go on the board - read schematic, place proper resistors. Insure you have a MM.
    Step 2: build the chassis...what? when done with step 2 you've successfully built the chassis. There is nothing in it but you've built the chassis. If you've mounted the circuit boards you have a chassis with two circuit boards in it but no connections or connectors.
    Step 3: place the connectors - maybe step 2 should go at the end?
    Now realize that the pictures are not of the connectors you have. Wing it.
    Step 4: wiring... "use some wire". ok...I can do that, but how much? Do I have enough?
    I think the major whoops is step 2 - it needs to go later in the build.
    Again - doable...but could be so much better!
    I'm at step 1.5 - realize that step 2 is in the wrong spot and how do I figure out how much wire to use with it disassembled so at assembly I don't come up short or have an extra 10' of wire in here.
    Bitchin' session over...
    Aaron
  • mlistens03
    mlistens03 wrote: »
    pieces.
    are.
    good.
    Yoda Trioda
    HA! Love the Star Wars reference.
    I actually fully disassembled a receiver the other day (an Onkyo TX-V940) down to every single board, and actually put it back together! My skills are increasing!! :wink:
    edited August 2018
    mlistens03 wrote: »
    mlistens03 wrote: »
    pieces.
    are.
    good.
    Yoda Trioda
    But does it work???
  • mlistens03
    mlistens03 wrote: »
    mlistens03 wrote: »
    pieces.
    are.
    good.
    Yoda Trioda
    But does it work???
    uh... I-uh... hmm... well... ye-no. :wink:
    But in my defense, it was already broken when I started. The only reason I took it apart was to find something amiss... but, alas, there was nothing to be found.
    SCompRacer Posts: 8,352
    ALL212 wrote: »
    Nice work but you need a refresher course on symmetry. Phillips screw heads should all be clocked in the same position. :D
  • ALL212
    ALL212 Posts: 1,556
    I had to throw the whole thing away... I couldn't get all the screw heads clocked right.
    Finis… The directions just plain suck but it is doable.
    Wire layout just prior to mounting the back panel:
    Cat 5 wire to led, their "speaker connection" wire to power supply, Mogami from inputs and a stripped out Canare wire to the speaker outs.
    Back panel completed:
    The Back of the back - middle connector does nothing but fill a hole. Use that for balanced in on mono's.
    The Front of the front - that switch - does nothing but fill a hole. Power switch is on the back where it should be.
    It plays! Will need to put it on something other than the test rig to see what it can do.
    Aaron
    Kewl! Nice work! I really dig the bat handle switch! We'll have to think of an alternate plug for the front panel switch.
    BTW, nice you see you got some class..... :D
    Nice!
    nooshinjohn Posts: 25,094
    SCompRacer wrote: »
    How about a power meter with a soft blue glow...
    The answer, right here!
    SCompRacer wrote: »
    Quickly, Robin! The Bat Handle Switch!
  • ALL212
    ALL212 Posts: 1,556
    SCompRacer wrote: »
    I thought I got shots to keep me safe from that!
    Aaron
  • ALL212
    ALL212 Posts: 1,556
    edited August 2018
    I gave it a real job. Volume on pre @ 3 o’clock
    Aaron
  • warren
    warren Posts: 756
    Not when its my gear. For me, pieces means that it may never be assembled correctly ever again. You paid your money and took your chances ...
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
    ALL212 wrote: »
    Sweet jebus, IIRC 88dB sensitivity? What a workout!
  • ALL212
    ALL212 Posts: 1,556
    And now a bit of crow...kinda.
    Found out the 1.6 build directions had yet to be done and are not yet released. So...you release a build without direction? No wonder I was a bit confused and aggravated.
    That back switch is for flipping between balanced and not balanced. Since I am not balanced and don't intend to be balanced it stays.
    The switch of the front is, indeed, the power switch on a normal build. I am also not normal so it stays as is, unused.
    BAJEEZUS!!!
    On the other hand - this thing is nice. The Carvers have its temp up a bit but nothing has caught fire yet. I've been listening for a couple of hours and no fatigue and no bitchin.
    Aaron
    SCompRacer wrote: »
    so, so close...
  • ALL212
    ALL212 Posts: 1,556
    What is really ironic is that, other than wiring and upgraded caps, I intended to build this stock.
    Oops . :#
    Aaron
