Tidal hifi streaming
So I just signed up for the 30 day trial and did some a/b testing back and forth with Apple Music. Quite a difference in audio quality. Will see if I actually get use out of it as the wife loves the seamless integration of Apple Music into our cars and phones, but as I type this I am listening to Tori Amos and and thinking I need to stop buying CD’s for a while and enjoy this service.
Any of you have this and have you compared with other streaming services and have anything to add?
  • Mikey081057
    Mikey081057 Posts: 7,127
    I use Tidal with Streaming Devices and a solid state PC and DAC. I've added a Chromecast Audio device as well. Certainly the best SQ and convenience option in audio. You can make up some great playlists like they were mix tapes B)B)
    Garage | Polk Monitor 5B's
  • joecoulson
    joecoulson Posts: 4,943
    I just have the Sonos connect which I know is no where near the best but it’s what I have currently. I have it connected to the Pre using toslink. So at least I am using the Marantz DAC and not the Sonos one.
    I would like to get a pro streamer, just not sure if I wanna drop $1500-3k on one. Not sure if the bluesound node 2 is worth $500 or if it will be a glorified Sonos.
  • joecoulson
    So that brings up a question I cannot seem to answer, is there much of a difference between that mini and the bluesound IF I am send the signal to a sep DAC? Would there be much difference in those from the Sonos for that matter? I get the DAC’s would make the most impact downstream, but is there that much of a difference in the way 1’s and 0’s are handled?
  • joecoulson
    Any thoughts on the Cambridge CXN v2?
    And no offense taken, will google the comparisons
  • rooftop59
    rooftop59 Posts: 7,976
    Love tidal! Use both a Bryston BDP-1 and a little NUC computer and while the bryston is definitely superior, the computer works great for causal listening and sounds really decent unless you are really listening critically, which I almost never am in the family room.
    I’ve bought maybe 5 cds in the last year...
    The next step is Roon, definitely takes it to the next level especially if your library is digitized.
    Game Room 5.1.4:
    Bedroom 2.1
  • Derf
    Derf Posts: 229
    @DSkip set me up with an Aries mini and North Star Supremo DAC which I use to stream Tidal. I really like the service. I added a Marantz SA8004 just because I wanted to try out SACDs. Bought Santana’s “Abraxas” from MOFI. Tidal stream of the same album gives slightly more detail.
    Integrated Amp: Marantz PM-10
    Speakers: Usher MD2
    Subwoofer: Rythmik F15HP
    DAC: North Star Design Supremo
    Streaming Source: AURALiC Aries Mini
    SACD Player: Marantz SA8004
    Power Source: PS Audio PP3 on dedicated 20amp circuit
  • Mikey081057
    Skip is your experience with the Node or the Node2 ? Important to note that the Mini is an end of life product and only integrates with IOS where the Bluesound products integrate with IOS Android Windows MAC Chrome OS and receives many updates and excellent support as a current product. I would be curious to do a comparison with Fred's mini /North Star rig vs my Node2 Mytek Brooklyn DAC+.
    Maybe we can meet up after Hurricane season Fred?
  • Derf
    Derf Posts: 229
    Sounds good, Mike. Look forward to it!
    Speakers: Usher MD2
    txcoastal1 Posts: 13,132
    Derf wrote: »
    Let me know when this may happen :)
  • Mikey081057
    You coming to SW FL Ronnie?
    edited August 2018
    If timing right I'll puddle jump from Pensacola to Tampa area for $250
    Just need 3 weeks notice
    In the future may have a Buc-ee's coming to your area. There are 4 on the schedule, only disclosed are Daytona and St Johns
  • Mikey081057
    Cool but we are closer to Fort Myers... Tampa is about 2 hours north of me and about 3.5 hours north of Fred...
    Nevermind there are no non stops.... we will work it out
    Driving 2hrs for me is like most people driving 30min...can do a lot of business on the ground :)
    This is my route this Thursday and Friday
    tonyb Posts: 32,906
    txcoastal1 wrote: »
    Yeah, we know. You and Tom have a lot in common it appears. :p:p:D:D
    tonyb wrote: »
    txcoastal1 wrote: »
    hey now, you're the one with pics on your cell phone :p
  • Derf
    Derf Posts: 229
    txcoastal1 wrote: »
    Sounds like we’re getting a party started!
    Speakers: Usher MD2
  • Mikey081057
    They're not just on his phone the NSA has them too!!!
  • Mikey081057
    Intriguing B)
  • joecoulson
    Skip. Was trying to locate that Aries mini to no avail. Any ideas on where to find?
  • rburgess714
    The mini is hands down one of the best audio purchases I have made over the last couple years. Easy to use, sounds great a lot of bang for the buck. Worth waiting for on the used market.
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
    Office
    Yamaha A-S501, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
  • Rich502
    Rich502 Posts: 146
    I agree, can’t believe I didn’t pick one up when they were still making them. Now to find an alternate, that does the same thing, even if slightly more money.
  • steveinaz
    steveinaz Posts: 19,522
    Does Tidal have like a radio function where you can just tell it you want classic rock, and it will play songs? Like Pandora?
    Clipdat Posts: 12,601
    edited August 2018
    As far as I could tell, no. You can tell it to generate playlists based off a certain artist, but it was always the same playlist per artist, in my experience. I wish that it had a radio feature like Pandora.
    You can pic genres, if that’s what you are asking
  • steveinaz
    txcoastal1 wrote: »
    Will it play a genre of misc songs, or do you have to pick and chose each song?
  • steveinaz
    edited August 2018
    Oddly, I know Pandora is basically stone age, but I love the radio like feature. As an example I created the "Kansas Channel" and it is awesome. It nails the songs I'm looking for in classic rock.
    Funny thing, Pandora "free" sounds way better than XM.
    It will show a list and then you could edit or hit play
  • steveinaz
    edited August 2018
    So, if I select genre, then Rock, and hit play; it will play a mix of rock songs?
  • Mikey081057
    In addition.... Roon has a feature called Roon Radio that you can select to play a similar genre mix of music after playing an album which is pretty cool.
