Owens Corning acoustic panels on sale today at Home Depot
    mhardy6647 Posts: 32,926
    wow, looks like quite a deal!
    F1nut Posts: 49,711
    If one paints the outer material does that not inhibit the panels ability to absorb sound?
    pitdogg2 Posts: 24,481
    edited August 2018
    One would think YES
    I can't believe the colored versions are so much more expensive.
  • delkal
    delkal Posts: 764
    I was thinking the same thing. You certainty wouldn't want a hard gloss enamel paint.
    But I don't even know how a flat surface can "suck up" the sound. Is it some kind of fabric coated foam? Can my 24x48 velvet picture of Elvis do the same?
    F1nut Posts: 49,711
    You can buy acoustic panels from Soundproof Cow or Acoustical Solutions at their regular price for slightly more than Home Depot's sale price and you have a lot more fabric and edge options.
    F1nut Posts: 49,711
    edited August 2018
    delkal wrote: »
    The fabric covers a fiberglass core, which is what really absorbs the sound. Of course, the sound has to be able to pass thru the outer covering.
    The velvet will absorb some sound, but Elvis may not like what he's hearing.
    SCompRacer Posts: 8,350
    edited August 2018
    SonoKote sells an acoustically transparent paint. I have no experience with it, just read about it being available. Be interesting to see what the difference between acoustic paint and fabric would be. I'm thinking fabric would be better but don't honestly know.
    One can always buy acoustic fabrics in colors of choice, like Guilford of Maine, for their diy treatments. I purchased some GoM fabric when I recovered a four GIK thick panels to match the four GIK bass Tri Traps I had purchased. The wife chose the color so it was easier to have them. lol
    Some sellers have a minimum quantity of fabric you must purchase, others will sell by the yard but you may pay more per square yard.
  • Use paints specifically for textiles, should not be a problem.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
    F1nut Posts: 49,711
    edited August 2018
    I don't think the average person would consider that and it might be difficult to get textile paint that matches wall paint.
    The Home Depot video does not mention anything about the type of paint being used.
  • Hermitism
    Hermitism Posts: 4,192
    Food coloring. I win.
  • DaveHo
    DaveHo Posts: 3,471
    Fabric dye. Make some tie-dye t-shirts with the extra.
    Tony M Posts: 11,009
    edited August 2018
    I thought the video said primer and then latex or acrylic paint. Yep, it does.
  • That is what fabric paint is, acrylic.
    F1nut Posts: 49,711
    edited August 2018
    Tony M wrote: »
    I stand corrected. Yeah, no way that's fabric paint.
    Post edited by F1nut on
  • BlueFox
    BlueFox Posts: 15,251
    Apparently, you can order it paintable.
    “The cores of our SolSerene panels are constructed with a rigid acoustical core and are then covered with either an acoustically rated fabric or with a paintable surface. ”
    F1nut Posts: 49,711
    Yes, I know. The issue is after it's painted how well does it do at absorbing sound?
  • motorhead43026
    motorhead43026 Posts: 3,892
    edited August 2018
    Tony M wrote: »
    I stand corrected. Yeah, not way that's fabric paint.
    Right the video has latex/acrylic paint, not fabric. I would think fabric paint would be less likely to inhibit sound absorption. That is the only reason I mentioned it. Sure your choices are limited , but most people want a contrast anyway.
  • BlueFox
    You just need to play music loud enough to break through the paint. :)
    To me, they are too plain looking. I have seen others with designs, patterns, etc on them that are more appealing.
    edited August 2018
    BlueFox wrote: »
    That would be me on certain occasions. :D:p
    I don't get the solid surface panel either. Maybe they think the sound entering from behind will be absorbed. But if the front is solid, it would act as a radiating panel, although the sound would be lower in volume due to some reduction from the panel catching some of the soundwaves.
    I agree, I don't get the solid surface idea either. Cloth, yea. 100% ;)
