SDA 1C
Hey,
New to this forum. I recently purchased a pair of SDA 1Cs. The 6.5" inch drivers on the right channel need to be replaced. I have learned that it is difficult to find the MW 6510 and MW 6511 and (it appears) the "replacement" MW 6503. Is there a source for these?
  • westmassguywestmassguy Posts: 6,068
    Call Polk Customer Service 1.800.377.POLK (7655) Option 1
    Be sure to tell them you're a Club Polk member.
    Home Theater/2 Channel:
    Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
    Interconnect: Furez 10/2 with SpeakONs
    ICs: Custom Furez by Douglas Connections
    Den:
    Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
    Carver CT-3 Pre, Carver C-500
    dhsspeakerservice.com/
    Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
    "And keep her under 70, would you, huh? Betty likes a slow ride"
  • mlistens03mlistens03 Posts: 1,407
    edited August 2
    What is wrong with the drivers? The magnets may have slipped, which is a time consuming but fixable problem.
    Also, I don’t think that the MW6503 is a suitable replacement for the MW6510/MW6511, but I’d let others pitch in on that front before you make any conclusions on them not being compatible. I’m still new to the SDA line.
    I also think that Polk still manufactures replacement drivers for these speakers, but I think they are different enough that you will need to replace all of the drivers in the left and right speakers, unfortunately.
    And welcome to CP!
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
  • NothusNothus Posts: 4
    No sound comes from the drivers. They make scratching sounds when gently pushed by hand. The drivers on the left speaker produce sound and make no noise when pushed or doing the leak check by pushing the passive. I pulled one driver and ohm'd it out Fluke DMM read OPEN.
  • pitdogg2pitdogg2 Posts: 10,242
    Slipped magnets.
    Call polk or take your chance buying used OEM off eBay. Be sure to cut a relief where the screws go or you will tear the rubber and ruin a new speaker. Believe us even if it doesn't appear to damage the rubber surround, It will and it will ruin the driver. Many have learned the hard way.
  • FestYboyFestYboy Posts: 2,530
    Slipped magnets can be repaired. I did a write up somewhere 'round here showing part numbers, supplies and how to build a jig. It's a 2 day process only because the adhesive needs to set 24 hrs. Otherwise it would take 10-20 min per driver.
    Okay, are the magnets actually loose or do they loosen and then the adhesive reseals the out of position. Also what are the symptoms of a shifted magnet?
  • F1nutF1nut Posts: 39,993
    The magnets generally shift, but sometimes they fall off. The scratching sound you heard is an excellent indication, but not always. If you didn't apply even pressure around the driver as you pushed in it will make a scratching sound. Just pull the drivers in question and look at the back, it'll be bloody obvious if shifted and no, the adhesive does not re-adhere.
  • la2vegasla2vegas Posts: 2,632
    One of the members here fixes shifted magnets free of charge. All you have to do is pay for shipping to and from. Reach out to him, he's @lawdogg.
    2.3TL, 3.1TL, SDA 2B, SDA II, 7B, 7C, 7 series 2, 10B, 5JR+, 5JR, 5A, 4.5, 4, RTA 11T X2 pairs, RTA 8T, LSI9, LSI7, RTI A7, RTI A3, CSI A4, CSI A6, F/XI A4, RTI4. That's all for now.
Howdy, Stranger!
