Signature S20 & S15 And competetives from RTiA
shabyshaby Posts: 6
Hi,
How are you?
1. I want to know if by your opinion and/or feeling there is A tangible(hope it the right term) defference between the S20 & S15?
2. RTiA series stands at the "same line" +- with Signature?
If do - what would be the competetive model? (for S10&S20)
3. The S20 feels really heavy.
Is it something that I need to be aware of in A matter of the cabinet that hanges to the wall and THE WALL needs to "carry" cabinet&Amp&3 sp(centre too)?
Thank you very much!
  • Viking64Viking64 Posts: 2,809
    shaby wrote: »
    Hi,
    How are you?
    I am just swell. How about you?
  • F1nutF1nut Posts: 39,985
    shaby wrote: »
    Hi,
    How are you?
    The S20 has a tad more bass and a bit bigger sound.
    The RTiA series is aimed more for home theater while the Signature series isn’t as hot up top, so a bit better for music.
    The S20 is a stand mount speaker, not a wall mount.
  • shabyshaby Posts: 6
    @Viking64 Am I missing something?
    @F1nut Thanks for your answer (:
    My needs are HT.
    I listened to the S20 And yet To the RTiA .
    I was impressed from the S20 - sounds lilke much more than 249$ sp.
    I had no plane to mount to use stand mount.
    The sp will sit on the cabinet.
    Although the S20 is A bit better for music and I liked it?
    Do you(and others) think that it better to find A shop that have the RTiA and to try it too?(which model is at the "same line" +- with Signature?)
    Thanks very much!
    shaby wrote: »
    I'm just saying "How are you?" to a new member. :)
    shaby wrote: »
    My needs are HT.
    Thanks very much!
    I think you'll be happy with the Signature series.
    Viking64 wrote: »
    <3 :)
  • cfrizzcfrizz Posts: 12,960
    Welcome to Club Polk Shaby!
    The Signature Series is outstanding for both music and movies. They managed to make a speaker that puts out very decent bass, and the tweeter is crystal clear without being overly sharp.
    If you are doing movies, I would strongly recommend having a sub to handle the lower end, which will allow the drivers in the speakers to handle the mid bass that they were designed to handle.
    Sunfire TGP III PrePro, Sunfire Cinema Grand Signature 405wpc 5 ch. Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony Bravia KDL-40R510C TV, Polk S60 Main Speakers, Boston VR-920 Center Channel, SVS NSD-12 SB12 Subwoofer, Polk DSW 400 Subwoofer, Polk FXi-3 Surround Speakers
  • mrlorenmrloren Posts: 1,405
    I went from RTi's to the Signature line. My wife and I like the Signature line a lot better.
    Family Room:
    Samsung UN60H,
    Marantz SR5010, Emotiva BasX-A300
    Oppo BDP-93,Sony UBP-X800BM, Sony DVP-NS3100ES, WD Live HUB.
    Main: Polk Signature S60
    Center: Polk CSi-A6
    Front High TC80i
    Rear: Polk MC80
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S35
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Polk RTi4 about 15' up the wall
    Old sony 12" Sub
    Mini tower PC with 400GB of music
    edited July 25
    The set would be:
    Front: S20
    Surround: S10
    Center: S30
    Sub: my current one - Cambridge Audio X200 subwoofer(Bc's I dont have space under the cabinet and Is just incredible **not only for his sizes)
    Thank you All so much!!!!
    Let us know what you think after you get it all set up.
    edited July 25
    Sure!
    Hope my responde on 7-10 days from now would jump it into the top
    B.T.W: How do you set it up that you'll get A notification(email) for A new comment?
  • mlistens03mlistens03 Posts: 1,405
    Scroll to the top of the page, and under your name on the right there are four options, the one all the way to the right is options. A little drop down menu will pop up, select “Edit Account”. Then once that page opens up there should be a list of different settings to change, third one down is “Notification Preferences”. You will then find a list of things to be notified for.
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
    Must say the final thoughts(or just one ;))
    OUTSTANDING !!!
Howdy, Stranger!
