Polk Audio PSW10..............what do you think?
KaraokeAmericaKaraokeAmerica Posts: 8
edited July 30 in Speakers
I have a room that is roughly 12x19 feet.
I am running a Denon AVR-S730H, two pairs of Polk T-15's, a T-30 center channel speaker and I'm looking at a sub. Ultimately I'm going to go Atmos, but for now a sub is the next addition.
What is the opinion of this one:
Polk Audio PSW10
https://www.amazon.com/gp/product/B0002KVQBA/
It's hard to beat for the $$$ if it's anything like the T-series speakers I own. Anything I'm not considering here? It seems like a good fit!
  • rpf65rpf65 Posts: 1,720
    I think you should up your budget and get a good sub.
  • rpf65 wrote: »
    I don't understand. Are you saying that is not a good one?
  • VR3VR3 Posts: 22,069
    The subwoofer is $100 speed with 2 day shipping....
    It will hit as low as a good pair of tower speakers
    Vr3Mods.com ///// Version3Audio.com
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
    Psw505 on there for 200
  • mlistens03mlistens03 Posts: 1,405
    The PSW-10 presents good value, but you can go up a hundred bucks or two and get something a thousand times better. And if it was any more expensive, it could probably be considered junk. It could probably be considered trash now TBH.
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
    rpf65 wrote: »
    Looks like you’re building a HT set up.
    The PSW 10 doesn’t have an LFE input. This is the .1 channel, and it is a recognized channel in the sound mixing process. Your AVR is designed to send that signal, this sub doesn’t have the input to receive that information.
    Specs say it can dig to 35Hz. Not good at all for HT duty, and barely acceptable for a budget music based system.
    No, I do not consider the PSW 10 a good subwoofer. You can get much better subs for not much more.
    The above mentioned PSW 505 is much better choice, for not a lot more. It has the LFE input, and the specs say it will dig down to 23 Hz. You will hear many more explosions with it. It’s a pretty good budget sub.
    Those 2 reasons alone should have you considering a larger investment in a sub.
  • ClipdatClipdat Posts: 4,229
    @rpf65 I agree with your comments regarding performance, but the PSW 10 clearly has a LFE input.
    Got Dayens?
    Guy at work asked me what LFE was 3 or 4 weeks ago. Said he was looking at subs, and a review he read on the PSW 10 said it didn’t have an LFE input. Looked and a few of them mentioned the same thing.
    Guess they figured if it isn’t labeled LFE, it just isn’t an LFE input.
    LFE input, in my experience, generally has no filter as the filtering comes from the AVR. In the event of the PSW10 you would crank the crossover up as high as it would go and then use the filters from the AVR so you do not double filter
  • KaraokeAmericaKaraokeAmerica Posts: 8
    edited July 30
    rpf65 wrote: »
    rpf65 wrote: »
    Thanks for all the info. Yes, I'm putting together a HT setup.
    I've had a "setup" all along, but it's been an out of the box, off the shelf, Onkyo 5.1 setup about 2010 vintage. It works sufficiently when weighed against any realistic upgrade since I have no viable way to update wiring or add additional speakers for examples. The living room is on the first floor of a 2 story house and the wiring was done when it was built so if it isn't in there now it's not going to be! That setup has a sub, but it's an off the shelf Onkyo setup. Not expensive. Again....sufficient for putting cartoons on for my son and low volume, 2-channel, family movie night.
    I acknowledge that although I truly appreciate all the stuff I consume in a theater and at home, I am not en expert in equipment. Frankly, I was ripping all my movies....even BR....to stereo because I didn't really understand it. I just kind of ripped and played. Currently I do that from a Plex server to whatever device I'm viewing on including phones etc. This HT I'm putting together now is in my "man cave". It's an open, 2nd floor loft, but I have a projector and eventually I'm going to go full Atmos. I'm a believer in buying stuff when it's a good deal, not when you need it, so it's been a long term project.
    All that being said, thanks for the feedback on the sub. I see the 505 and added it to my cart. No issue with the price, but I also know that more $$$ does not automatically mean better, so that's why I threw it out here. I know the 505 is 2" bigger, but other than that I'm not an expert, like I said. I can walk through Fry's and see $1000+ subs on display and think to myself that I don't care how good it sounds, I'm not spending that kind of cash on a speaker. I can always upgrade down the road, but if you buy a $1000 sub and don't like it, I don't think it would be a good investment.....
    I am not buying this immediately so I appreciate any more feedback! Even if I stick with a 505 at least I can learn something from your comments!
    Thanks all!
    Investment just depends on how you look at it...
    PSW505 - purchase price $200 - use it 3 years, sell it used $80, cost $120. if it breaks (known for amp issues within the first 3 years - throw it away, cost $200
    SVS subwoofer - $500 - use it for 3 to 5 years, sell it used for $300 to $350 all day... long term cost $150 to $200
    Value is relative...
    Find a stellar deal on a used sub that used to be $1,000 for $350 - use it for 5 years, sell it for $350, cost $0
  • lightman1lightman1 Posts: 9,691
    VR3 wrote: »
    Sid the Kid knows how to wheel and deal....
    lol... that or I just realized a long time ago that anything in life cheap is actually very expensive.
    You cant resell junk.
    If your not in a hurry for a sub look at the following internet direct sites:
    Hsu Research
    Power Sound Audio
    Rythmik Audio
    SVSound
    These are probably the most popular reasonably priced sub companies.
  • rooftop59rooftop59 Posts: 4,312
    edited July 31
    VR3 wrote: »
    This is exactly where I have ended up. Do your research, buy good used equipment, and you can use it for 1-3 years (often more) and lose little to nothing on your initial investment. I haven’t bought a new piece of equipment in years...
    On the other hand, some people just don’t want to mess with research, buying used and with buying and selling. If that’s you then buy the psw10 or preferably 505 and call it a day. Chances are you’ll be happy...
    HT Rig:
    Denon AVR-X4200w; Parasound HCA-1205A; Arcam rDac; Mains: Dynaudio Emit 10 + MartinLogan Dynamo (original) sub; Center - Def Tech Procenter 1000; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - SVS PB10-ISD; Sony BDP-S390, FireTV gen 2
    Master Bedroom
    Marantz SR-5007; Audiosource Amp Two, PSB Imagine Mini, Boston VR-10 center, NHT Super One CI surrounds, ACI Titan subwoofer, FireTV, Arcam rDac; Bryson BPD-1
  • zuulzuul Posts: 252
    fwiw i have a psw10 but i don't use it for HT. for music it's competent... obviously... as others have mentioned there are certainly better options out there.
    for me it was about cost. i got it almost brand new for $60 on craigslist. you can get a used psw10 on craigslist for between 80-100 bucks. i would try it out... if you hate it... you can flip it and get something better.
    also... i can confirm there is no LFE input on the psw10. there's a line in so you can go from the pre-out on your preamp/receiver into the line level inputs on the psw10... LFE is a separate connection... typically with one yellow rca... not red and white/left right rca's like a line level input.
    speakers:
    bowers & wilkins 685 S2
    polk psw-10
    components:
    sonic frontiers line 1 preamp
    sonic frontiers anthem amp 1
    mac mini w/ audioquest jitterbug
    teac ud-501 digital to analog converter
    oppo dv-980h dvd/cd
    interconnects:
    guzi rca
    monoprice onix series digital coaxial
    transparent performance USB
    transparent perfect image HDMI
    speaker wire
    audioquest type 4
    power:
    rhino-tek 1000w 15amp voltage regulator
    vansevers 211 power cord
    pangea ac-14 power cord
    tubes:
    amplifier: (2) NOS 1960 philco/lansdale 12AU7 (super rare!), (1) NOS 1967 mullard 12AX7, (4) 2016 svetlana hard blue EL-34
    pre-amp: (6) E88CC/6922 ??? (haven't cracked the case yet to see what previous owner was running...) so for now they are mystery tubes.
    misc:
    JRiver Media Center 24
    sanus 24" speaker stands
    auralex acoustics subdude II
    DeMoude Audio cylindrical bass traps
    rf/emi/noise reduction caps for empty rca inputs.
    Hall of Fame: [retired/sold]
    polk monitor series 5jr+ w/ RDO194-1 upgraded tweeters
    polk monitor series RTA 8T
    kenwood kd-550 w/ SME 3009 Series III tonearm grado gold cartridge
    adcom gfp-555II
    marantz 2238b
    luxman M-120A
    technics sl-b10
    edited July 31
    I guess I thought line level inputs were the same as LFE. I was wrong:
    "On sub amps that are equipped with both, the 'LFE input' USUALLY bypasses the sub's own low-pass filter (sometimes called its 'crossover'), completely. And the low-pass filter setting WOULD be applied to the other pair of inputs. When connecting a sub conventionally, to an AVR's sub out, the 'LFE input' would be the preferred connection on a so-equipped amp.
    But if your amp doesn't have this sort of 'LFE input', and it has no sort of low-pass filter bypass switch, and you are connecting the sub conventionally to your AVR's sub out, then set the amp's low-pass filter setting to the highest possible setting. "
    "When using LFE, the receiver will send all the low frequencies to the subwoofer. You will have to set the xover frequency on your receiver to achieve this. So if you set it at 80hz (wich is the recommended setting for use with towers) anything under that 80hz will be handle by the sub. You have to make sure your speakers are set to "small" for this application.
    When using "line in" all the low frequencies that would normally go to your L / R, speakers, will be "intercepted" by your sub. You will have to use the xover frequency directly from your sub to achieve this. You have to make sure your speakers are set to "large" for this application. This method although not as popular, tend to have the same effect as not much content under 80ishHz (from a movie soundtrack for instance) would be directed to your surround back and or your center."
    rpf65 wrote: »
    Got Dayens?
  • rooftop59 wrote: »
    VR3 wrote: »
    Thanks. I have no issue with used equipment. I buy used cars. lol
    The issue for me was that I don't know enough about the "value" to know if spending $300 is going to do more for me than the $150 model. Enough to be noticeable anyway....
    I'll start looking around at the local papers. I'm always up for a good deal!
Howdy, Stranger!
