LSiM 705 have arrived
Excuse my ignorance, which graph is for which speaker?
The top graph is the "bad" left speaker and with a ~250 Hz signal, you can see the harmonics at 500 and 750 Hz are only 20-30 dB down and there is lots of hash at higher frequencies. With the "good" right speaker, bottom, you don't see any obvious harmonics. This was all done with my phone and used to show Polk the nature of the distortions.SONY VPL-VW385ES, Da-Lite 92" 0.9 HD progressive 16x9 screen, Apple TV 4K, Oppo UDP 203, Anthem AVM 60, D-Sonic 4000 (800x3, 400x4) for bed layer, 2 Crown XLS 1002 (225x4) for Atmos; Speakers: Polk LSiM 705s, 703 front, 4 702F/X surround, 4 Polk TL3 (Atmos), Velodyne DD15 Subwoofer.
Thanks again for the clarification, I sincerely appreciate it.
What did that distortion sound like when you were playing music? Was it obvious? -
The answer to your last question is, yes and no. With music, it depends and only happened when there was fairly strong content in the mid-bass frequency range. Also, this type of harmonic distortion is often done on purpose, e.g. “fuzz” with electric guitars, and in the colloquial, sort of sounds like farting. When I first heard it watching TV, I wasn’t sure whether it was part of the soundtrack, e.g intentional fuzz, or a problem with the speaker. However, I was hearing it more than I thought I should, so checked with a frequency sweep, and it was very obvious as distortion when played through the left channel but not the right. The fact that I could stop the distortion by lightly touching the driver’s surround told me that the mid-bass driver was being driven outside its linear range. I snapped an FFT analysis to get some idea as to the magnitude of the distortion, as can be seen above.SONY VPL-VW385ES, Da-Lite 92" 0.9 HD progressive 16x9 screen, Apple TV 4K, Oppo UDP 203, Anthem AVM 60, D-Sonic 4000 (800x3, 400x4) for bed layer, 2 Crown XLS 1002 (225x4) for Atmos; Speakers: Polk LSiM 705s, 703 front, 4 702F/X surround, 4 Polk TL3 (Atmos), Velodyne DD15 Subwoofer.
Great job on recognizing and diagnosing the issue!
Now I have to be über diligent when listening for any issues.
Thank you for posting this information.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
In my opinion, the mid bass driver (which I have already replaced one in my 705’s) are the weak links of these speakers. Otherwise very stellar.
joecoulson wrote: »In my opinion, the mid bass driver (which I have already replaced one in my 705’s) are the weak links of these speakers. Otherwise very stellar.
Hmmm. Design flaw?
Not sure. They seem to move more than the subwoofers when driven hard. Could be a design flaw in the power distribution between the drivers but I’m not sure.
Ok. I don’t drive them that hard. Even when I played the soundtrack to Blade Runner 2049 the only drivers visibly moving were the Cassini woofers / subsAudio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
Crossover to the cassinis is too low IMHO. That said, they sound spectacular withn the limits.
Crossover to the cassinis is too low IMHO. That said, they sound spectacular withn the limits.joecoulson wrote: »I agree
Would’ve been nice to know this before I bought themAudio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
Not saying I don’t love them, I do. But even great products have their flaws. You will not regret buying them.
While they are not SPL monsters, you don't need to baby them. I have never bottomed out the mid-woof. That said, when running them full range, the 5 1/4 driver really moves. Play Pink Floyd, Mother & crank it up some. You'll see what I mean.
Agree with Dave ^^^^ above
Right after the 705's were born and Russman still was a Polk rep we jammed these babies at LSAF for their debut...and you know how we do it at LSAF
From 12watts to 200+ watt amps these babies can play....do a search here on the forum2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Performed this "test" with no major cone movement visible. This is probably because I live in an apartment & the "loudest" listening levels I get to here aren't very loud (perhaps by forum standards?). lol.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
The 705s certainly play loud enough for my purposes, and I live in a large house some distance from the neighbors with a dedicated home theater. Let's see if my signature block now has info. Tried several times, but no luck.SONY VPL-VW385ES, Da-Lite 92" 0.9 HD progressive 16x9 screen, Apple TV 4K, Oppo UDP 203, Anthem AVM 60, D-Sonic 4000 (800x3, 400x4) for bed layer, 2 Crown XLS 1002 (225x4) for Atmos; Speakers: Polk LSiM 705s, 703 front, 4 702F/X surround, 4 Polk TL3 (Atmos), Velodyne DD15 Subwoofer.
Nice reviews...considering getting a pair of 705's myself.
You're in luck.... There is a big amplifier of mine floating around near you. Call Doc.
It is true, but the amplifier in question is still in rehab.We wanted it to go to rehab, and we said, yes, yes, yes. -
Hey Vic just caught this. Yes it is! I've got it paired with the VTL pre and SRS's with new tweeters. Still breaking em in, but so far sounds fantastic! Was playing the new Bill Idol album rather loud last night and the CJ didn't break a sweat!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Just out of curiosity...why did you sell them?Denon X7200WA
LSiM 705 703 704c
Denon DP 400
Yamaha CDC 775 -
They were not a good fit for the rest of my setup. I preferred the sound of the Signature S60 speakers > that of the LSiM 705 speakers in my listening environment & on my gear.
I have since sold the Signature S60 speakers and I am now using Usher CP-6311 floorstanding speakers.
I hope that helps you. If you have any more questions, don't hesitate to ask.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
That really is helpful. As a happy S15 owner, I can understand the appreciation for the Sig series.Denon X7200WA
LSiM 705 703 704c
Denon DP 400
Yamaha CDC 775 -
What was the app used to get these graphs?Parasound Halo Integrated, Pioneer SC-LX 901, Oppo-205, Revel F208 + Heco Aurora Center 30 + Heco Victa Prime 202 -
Those graphs were made with SignalScope on my iPhone.SONY VPL-VW385ES, Da-Lite 92" 0.9 HD progressive 16x9 screen, Apple TV 4K, Oppo UDP 203, Anthem AVM 60, D-Sonic 4000 (800x3, 400x4) for bed layer, 2 Crown XLS 1002 (225x4) for Atmos; Speakers: Polk LSiM 705s, 703 front, 4 702F/X surround, 4 Polk TL3 (Atmos), Velodyne DD15 Subwoofer.
Those graphs were made with SignalScope on my iPhone.Parasound Halo Integrated, Pioneer SC-LX 901, Oppo-205, Revel F208 + Heco Aurora Center 30 + Heco Victa Prime 202
That should be fine. I was not using REW at the time and love it now. Before I was using a sweep on a test CD and SignalScope as the RTA. In my case the distortion happened only during a fairly specific frequency range and I would have to pause SignalScope and save the image when I started to see the distortion. I would think that the RTA function of REW would work fine for capturing this sort of thing.SONY VPL-VW385ES, Da-Lite 92" 0.9 HD progressive 16x9 screen, Apple TV 4K, Oppo UDP 203, Anthem AVM 60, D-Sonic 4000 (800x3, 400x4) for bed layer, 2 Crown XLS 1002 (225x4) for Atmos; Speakers: Polk LSiM 705s, 703 front, 4 702F/X surround, 4 Polk TL3 (Atmos), Velodyne DD15 Subwoofer.
I only bought umik few days ago and really inexperienced in Rew at all so would have to figure out how to use rtaParasound Halo Integrated, Pioneer SC-LX 901, Oppo-205, Revel F208 + Heco Aurora Center 30 + Heco Victa Prime 202
I you have not already, there is lots of help in the REW page on the AVS Forum.SONY VPL-VW385ES, Da-Lite 92" 0.9 HD progressive 16x9 screen, Apple TV 4K, Oppo UDP 203, Anthem AVM 60, D-Sonic 4000 (800x3, 400x4) for bed layer, 2 Crown XLS 1002 (225x4) for Atmos; Speakers: Polk LSiM 705s, 703 front, 4 702F/X surround, 4 Polk TL3 (Atmos), Velodyne DD15 Subwoofer.
