Signature S20 & S15 And competetives from RTiA
Hi,
How are you?
1. I want to know if by your opinion and/or feeling there is A tangible(hope it the right term) defference between the S20 & S15?
2. RTiA series stands at the "same line" +- with Signature?
If do - what would be the competetive model? (for S10&S20)
3. The S20 feels really heavy.
Is it something that I need to be aware of in A matter of the cabinet that hanges to the wall and THE WALL needs to "carry" cabinet&Amp&3 sp(centre too)?
Thank you very much!
How are you?
Hi,
How are you?
The S20 has a tad more bass and a bit bigger sound.
The RTiA series is aimed more for home theater while the Signature series isn’t as hot up top, so a bit better for music.
The S20 is a stand mount speaker, not a wall mount.
President of Club Polk -
@Viking64 Am I missing something?
@F1nut Thanks for your answer (:
My needs are HT.
I listened to the S20 And yet To the RTiA .
I was impressed from the S20 - sounds lilke much more than 249$ sp.
I had no plane to mount to use stand mount.
The sp will sit on the cabinet.
Although the S20 is A bit better for music and I liked it?
Do you(and others) think that it better to find A shop that have the RTiA and to try it too?(which model is at the "same line" +- with Signature?)
Thanks very much! -
My needs are HT.
Thanks very much!
I think you'll be happy with the Signature series.Political Correctness'.........defined
Welcome to Club Polk Shaby!
The Signature Series is outstanding for both music and movies. They managed to make a speaker that puts out very decent bass, and the tweeter is crystal clear without being overly sharp.
If you are doing movies, I would strongly recommend having a sub to handle the lower end, which will allow the drivers in the speakers to handle the mid bass that they were designed to handle.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I went from RTi's to the Signature line. My wife and I like the Signature line a lot better.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
The set would be:
Front: S20
Surround: S10
Center: S30
Sub: my current one - Cambridge Audio X200 subwoofer(Bc's I dont have space under the cabinet and Is just incredible **not only for his sizes)
Thank you All so much!!!! -
Let us know what you think after you get it all set up.Political Correctness'.........defined
Sure!
Hope my responde on 7-10 days from now would jump it into the top
B.T.W: How do you set it up that you'll get A notification(email) for A new comment? -
Scroll to the top of the page, and under your name on the right there are four options, the one all the way to the right is options. A little drop down menu will pop up, select “Edit Account”. Then once that page opens up there should be a list of different settings to change, third one down is “Notification Preferences”. You will then find a list of things to be notified for.
Must say the final thoughts(or just one )
OUTSTANDING !!!
