What's the difference between the USA peerless and the Denmark. Which is better
polk4life10122polk4life10122 Posts: 5
edited July 2017 in Speakers
  • FaustinFaustin Posts: 751
    Some say the Peerless that were manufactured in Denmark sound better than the ones manufactured in the US. Not sure if that is true or not. They look identical, the only difference is the serial numbers. Denmark ones start with 7514 and the US start with 5514. The last four numbers on both are the month and year manufactured.
  • geppy1geppy1 Posts: 2,563
    The Denmark made ones have a very clear focused image The US mad ones with the rough faceplate tend to be warmer with softer image outlines.
  • But what ones would u say are better. Do you think that the USA made peerless are good?
  • NightfallNightfall Posts: 7,545
    I wouldn't stress about it, they're both good even if they may sound a small bit different.
    afterburnt wrote: »
Howdy, Stranger!
