DK's AXPONA 2018 Experience - Pt. 3 of 3 - SDA 1C Modification
DarqueKnight
DarqueKnight Posts: 6,760
Introduction
When I told my friend and former Bell Laboratories colleague, Craig, that I was coming to the Chicago area for an audio show, he said "Great! You can modify my speakers now." For years I had been suggesting that Craig send his SDA 1C crossovers to be modified, and that doing so, along with a few other simple mods, would give him a virtually new set of speakers.
He actually was quite satisfied with his stock 1Cs until he recently heard a pair of Martin Logan electrostatics at his mechanics house. He called me shortly after that encounter telling me how impressed he was and asking me what I thought of Martin Logans. I reiterated that, for the instrumental jazz he favors, he would be happier with the result of modifying his 1Cs. I further predicted that after the modification:
1. He wouldn't like the Martin Logans any more.
2. He wouldn't need his subwoofer for music ("My SDAs don't put out enough bass.")
3. His 1Cs would sound like a significantly improved version of their former selves...like a 98 pound weakling becoming a champion bodybuilder.
Of course, Craig laughed me to scorn on all counts above. However, as skeptical as he was, he decided to trust me. It helped that Craig remembered that I had once had two pairs of modded 1Cs and that I wasn't just talking speculatively. I invited him to AXPONA on Saturday, when I would be through modifying both of his 1Cs, and when he would be able to compare what he was hearing at home to the Martin Logan electrostatics, and other speakers, at the show.
Figure 1. I don't usually make house calls, but I made an exception to bring a good friend
into the rabbit hole.
I arrived at O'Hare Thursday afternoon, checked into my hotel, then headed straight for Craig's house.
This modification exercise consisted of the following:
1. RD0194 silk dome tweeters.
2. Gimpod's boards.
3. Mills MRA-12 resistors.
4. Sonicap Gen 1 capacitors.
5. Larry's rings (double thanks to Brian!).
6. Adona black chrome spikes.
7. Vampire BP-HEX binding posts.
8. Armacell tape gaskets.
9. Dynamat Xtreme on driver and passive radiator baskets.
10. 4" x 12" Sonic Barrier strips behind drivers.
11. Fifteen foot 10 gauge SDA interconnect made from Monster Z2 Reference speaker cable
There were also some minor cosmetic issues to be addressed: Edge banding on the bottom end caps needed re-gluing in places. Side panels were coming loose in places.
The right speaker was done first so that Craig could hear the difference between the fully modded right speaker and the stock left speaker.
Figure 2. No evening fun this trip. I'd listen to gear all day at AXPONA and solder, drill, tape, and glue all night.
Figure 3. Craig didn't like the sound of the RD0 tweeters at first.
Craig thought the old SL2000 tweeters had more detail. I told him they had more distortion, and that the RD0s had a more natural sound, even prior to the required 50 hours of break in. When panning the balance control left to right and vice versa, he began to notice a more "metallic" sound in the stock speaker.
We let the tuner play overnight and all day. During the next evening's A/B listening session, Craig said of the left speaker "I can't go back to that". We then proceeded to modify the left speaker.
The only snag encountered with modifying the right speaker was the brace between the stereo and dimensional drivers was off center and too close to the cutouts for the stereo drivers. This meant the ring for the upper stereo driver had to be trimmed a bit with a Dremel.
Fitting driver rings in the left speaker was a nightmare. About nine tons of hot glue had to be chiseled and pealed away from the areas near the driver cutouts.
Figure 3. Sonic Barrier strips were placed behind the drivers for backwave damping.
Figure 4. Easy ring hole drilling.
Figure 5. Experimenting with position of the partially assembled new board.
I considered mounting the new boards in the bottom of the cabinet, but decided
to use the stock location. These boards are pure genius. They, and the extensive
online documentation, really make the crossover mod process a breeze.
Figure 6. Enjoy your retirement!
Figure 7. Vampire BP-Hex binding posts for speaker and SDA interconnect cables.
The left speaker, except for spike installation, was finished Friday night-early Saturday morning. Craig was thrilled with the results, but he said he never would have asked me to do this if he had any idea of the amount of work involved.
Craig joined me on day two (Saturday) of AXPONA. I took him to the Aida room first, then to the Wilson Audio rooms, then to the two Martin Logan exhibits, then we wandered around to different exhibits. He became increasingly agitated and asked "why does everything sound worse than the first room?"
As predicted, Craig:
1. Didn't like, or want, the Martin Logan electrostatics any more.
2. Turned off his subwoofer for music.
3. Was floored by the amount of improvement in his speakers. (I too was surprised at the transformation...and I have been around this block many times.)
Saturday night was spent installing spikes and making cosmetic repairs. I spent Sunday at the final day of AXPONA. Sunday evening was spent listening and discussing future stereo system upgrades.
Since the mod completion, Craig has had many questions about upgrading his electronics and cables...and so it begins...
    pitdogg2 Posts: 24,474
    Tossed him right into the abyss Ray.
    Nice job on both accounts :D:)
  • Moose68Bash
    Moose68Bash Posts: 3,842
    Well done, Ray!
    You saved another pair of remarkable, vintage speakers from the dustbin of history!
    Is Craig going to sign up on the Forum?
  • DarqueKnight
    Craig is a forum member...but he prefers to read rather than write.
  • erniejade
    erniejade Posts: 6,288
    Nice work!!
    Musical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
  • agfrost
    agfrost Posts: 2,421
    Nice work.
    Was it your first time using Gimpod boards? I know you designed/had made boards for some (all?) of your SDAs.
    Jay
  • DarqueKnight
    Yes, this was my first time using Gimpod's boards.
    I designed replacement boards for all of my SDAs.
  • Emlyn
    Emlyn Posts: 4,346
    If you flew to Chicago I hope you didn't try to take that suitcase as a carry-on bag! TSA would freak out. B)
    Nice work on the speakers, as usual.
  • DarqueKnight
    The tools suitcase was in checked baggage. TSA didn't have any interest in that suitcase. The suitcase they were very interested in was the suitcase that contained my clothes, and the box that the Sonic Barrier strips were in.
    Since O'Hare is one of the top 20 airports for theft by TSA officers, I did have a little concern about my tools making it in and out of O'Hare without being "detained".
    https://abcnews.go.com/Blotter/top-20-airports-tsa-theft/story?id=17537887
  • gimpod
    gimpod Posts: 1,793
    to use the stock location. These boards are pure genius. They, and the extensive online documentation, really make the crossover mod process a breeze.
    Thanks @DarqueKnight for posting that, coming from you it means a lot to me.
  • DarqueKnight
    I have professional and hobbyist experience designing circuit boards, therefore I can and do appreciate the thought and effort that goes into designing a single circuit board. Orders of magnitude more thought and effort is required for designing a single board for multiple crossovers.
  • honestaquarian
    honestaquarian Posts: 3,186
    Experience is THE BEST teacher.
    You can tell someone until both you and they are blue in the face, but once they experience it then ya got `em!
    Good work DarqueKnight B)
  • westmassguy
    westmassguy Posts: 6,850
    Very nice work!
    Home Theater/2 Channel:
    dhsspeakerservice.com/
