Farnsworth BC103
oldrocker
oldrocker Posts: 2,590
Came across this while out and about.
As usual, no clue on it but I'm sure my daughter will like the look and take it.
    Clipdat Posts: 12,589
    Very cool! What is that big cylindrical object? Looks a battery or something maybe.
    mhardy6647 Posts: 33,021
    It's a very nice console AM radio.
    Push-pull 6V6 output tubes are good for about 10 watts and that's an electrodynamic speaker -- using an electromagnet ("field coil") instead of a permanent magnet. The field coil of the speaker was often used as a choke (filtering inductor) in the high voltage power supply in such equipment.
    It will need some rehab if not done already, but should be a very nice radio.
    edited July 2018
    The can, as it says, is some sort of on-board AM loop antenna.
    I believe that the Farnsworth of Farnsworth is none other than Philo T. Farnsworth. If any single person might be eligible to be considered as the inventor of television, it is he.
    https://en.wikipedia.org/wiki/Philo_Farnsworth
    Note, also that the radio appears to have an input for a crystal pickup phonograph. :)
    What DON'T you know?! :o:p
    pitdogg2 Posts: 24,550
    Clipdat wrote: »
    big ferrite bar antenna good for AM only
    Clipdat wrote: »
    I -- I don't know.
    Clipdat wrote: »
    Why wouldn't he know, the radio and Doc are about the same age. I bet he cut his teeth chewing on the side of one of those or one like it....
    Clipdat wrote: »
    Pretty darned close.
  • Nightfall
    Nightfall Posts: 10,067
    There is only one Farnsworth. Professor Farnsworth.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • oldrocker
    Was an interesting read for sure.
  • oldrocker
    Nightfall wrote: »
    And I found him also while researching... :D
  • oldrocker
    Thanks for weighing in, had hoped you would.
    The lady I got it from said it works, I have not tried it yet.
  • oldrocker
    It was made approx. in 1940 as per some page I found earlier.
    Not a lot of info on it but as said earlier, the guy who thought the thing up is quite interesting.
    Crystal pickup phonograph? No clue as to that.
    And yes, sent the daughter a pic of it, she's on her way over to see it.... :D
  • oldrocker
    Ok, she claimed it, is going to her house.
    She suggested we work on this one together as a Daddy/Daughter project... B)
    well, the crystal phono cartridge is (was) the forerunner of the ceramic, piezo, and strain gauge cartridges that came later. High output, relatively limited frequency response, and heavy tracking weight (n the case of the crystal cartridges). The input is probably close enough to normal line level and impedance that mono output from a CD player, DAC, tape deck, tuner, etc. would probably sound OK within the limitations of the amp and loudspeaker.
  • kharp1
    kharp1 Posts: 3,453
    Wonder what a 2 into 1 RCA adapter would do? Would allow for both channels to be heard, but, would it double your input voltage?
    EndersShadow Posts: 17,527
    oldrocker wrote: »
    I’ve debated getting one of these or similar and remove the guts and use it to hide my furnace return without blocking airflow
    kharp1 wrote: »
    No it won't -- but -- here's what you need to know about the "best practice" approach to using a "Y connector" to mix to mono. It's not quite a trivial exercise for best results.
    https://www.rane.com/note109.html
    Full disclosure -- I've used a "Y" connector to mix to mono a million times... but that doesn't mean it's a good idea. :)
