Hooking up PSW10 to Dayton DTA-2.1BT
The Dayton DTA 2.1BT has a high level mono sub out with a 180 he low pass for a passive sub. Can I hook up to just one channel of the speaker wire input on the PSW 10? Will that affect output level of the sub. Or better to use the high level LR input and the out to the speakers? Or hook up the mono high level output to both speaker wire inputs?
Best Answer
Answers
  • popspensepopspense Posts: 2
    Thanks, I’ll just forget about the sub output and go with the LR outputs to the sub then to the speakers.
  • mlistens03mlistens03 Posts: 1,405
    popspense wrote: »
    Good luck!
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
Howdy, Stranger!
