Hooking up PSW10 to Dayton DTA-2.1BT
popspense
The Dayton DTA 2.1BT has a high level mono sub out with a 180 he low pass for a passive sub. Can I hook up to just one channel of the speaker wire input on the PSW 10? Will that affect output level of the sub. Or better to use the high level LR input and the out to the speakers? Or hook up the mono high level output to both speaker wire inputs?
Best Answer
If you have a bi-wire cable, you could have the single sided end in the Dayton and then the double sided end going into the Polk. At least, I think this would work, hopefully someone else will reply and verify.
If there is a way you can turn of the amplified sub output, I would recommend doing that and just using the front LR outputs to the sub, then the sub to the main speakers.
And welcome to Club Polk!
Micah
Answers
Thanks, I’ll just forget about the sub output and go with the LR outputs to the sub then to the speakers.
Good luck!
