Polk SDA-2b Tweeter is cutting in and out
windstriker
My tweeter on the left speaker cuts in and out when the volume is low. When I pump up the volume some(not earth shattering) it doesn't work at all. I have already tried replacing the tweeter but that did not fix the issue. How can I troubleshoot this problem?
Sounds like the poly switch in the crossover may have been tripped multiple times causing it to be overly sensitive.Just a dude doing dude-ly things
