Closest current line to SDA
eztommyd
eztommyd Posts: 10
Just bought a pair of S55s since I downsized and my wife said my SDA 2As were too big. I know, big mistake. The S55s have great clarity and bass but not the depth or field the SDAs had, of course. Now I'm trying to decide if I return them and get the RTia 7 or 9, if this will get me closer to the SDA depth and breadth I loved. I'll also eventually replace my Sony 100W receiver with a dedicated 200W amp but am wondering if I should upgrade to the amp first and give the s55s another chance? Or go with the RTia 7/9 now then upgrade the amp? I'm not looking for a lot of volume, just want the depth even at a lower volume.
    F1nut Posts: 49,708
    Neither the RTiA or LSiM will get you closer to the SDA.
    nooshinjohn Posts: 25,034
    There is no replacement for displacement
  • eztommyd
    eztommyd Posts: 10
    Ok, do the RTai 7s sound dramatically better that I should swap out the S55s for them? I've got nowhere close by to hear them first.
    I would look for the LSIm 705 instead. They are generally considered the best all around performer of the Polk line right now.
    F1nut Posts: 49,708
    ^ THIS ^
  • eztommyd
    eztommyd Posts: 10
    So no appreciable difference unless I go all the way to LSIm 705?
  • teekay0007
    teekay0007 Posts: 2,289
    Have you seen this thread? http://forum.polkaudio.com/discussion/182646/black-lsim-705-pair-with-center-for-1k-adorama#latest
    Sweet deal on a pair of LSiM705s and a center. If that isn't for you, I think you'd notice some nice improvement moving up, Amp-wise, and keeping your S55s. However, I think you'd get further improvement with the RTiA7s and the upgraded amp. And, lastly, you'd get the most improvement out of the amp upgrade and the LSiMs. Taking advantage of the above deal, you'd also need a three-channel amp.
    It's also my understanding that if you do go with the RtiA line, the 7 is as high as you want to go. I've heard from several present and past 9 owners that the 9's are very difficult to drive and even more difficult to get to sound well balanced.
    That being said...........YMMV! (your mileage may vary)
  • motorstereo
    motorstereo Posts: 2,042
    Hmmm; I wonder if there's anything close to the bigger SDA's sound by any manufacturer presently??
    Clipdat Posts: 12,558
    Honestly, no speaker can be properly judged when it's driven from an inexpensive HT receiver.
  • FestYboy
    FestYboy Posts: 3,861
    Gonna go out on a limb here and say NO. You're comparing apples and cumquats.
    heiney9 Posts: 25,053
    LSiM is a great performer, but there is nothing like the SDA's being currently made. They were unique then and there's nothing from Polk or anyone else that gives you what they did.
    2 choices, get another pair of SDA's or move on with something like the LSiM series and learn to love those. They really perform very well (above their price point), just not the same presentation as SDA's.
  • eztommyd
    eztommyd Posts: 10
    Do we know why Polk abandoned the SDA technology? It was a game changer in the 80s - cannot believe they think today's are somehow better.
  • eztommyd
    eztommyd Posts: 10
    Clipdat wrote: »
    Somewhat agree but I know how good my 2As sounded even with a moderate quality amp, so by using the same amp I have a baseline to compare.
    pitdogg2 Posts: 24,474
    eztommyd wrote: »
    They didn't its now a sound bar... :p
    edited July 2018
    eztommyd wrote: »
    Do a search, it's been discussed ad nauseum . Too big, required too much power, expensive to build. But really from an aesthetics stand point they just don't fit anymore. They also need a proper demo and many brick and mortar stores aren't around anymore. Any being a mass producer of speakers they couldn't make them a boutique product.
    SDA lives on actively in many of the sound bar units, but it's done electronically not passively. It works in the sound bars fairly well, but not like the big boy speakers of the late 80's early 90's
  • rburgess714
    rburgess714 Posts: 614
    I had the A7s for a short time and returned for the S60s. To my ears they were much better for music and not bright. They weren’t for me but others like them for ht or tame them with amps that are on the warm side and ICs and cables.
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Yamaha BD-S681, Cambridge Audio Azur 851N, Polk S60, Polk S30, Samsung 60" LED
    Office
    Cambridge Audio 851A, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
    tonyb Posts: 32,902
    If the wife finds the SDA 2's too big, how on earth does she ok the RTIA'S , lsim's ? I think it's more aesthetics than size.
    Might be time to start looking at a higher end speaker if you want that breath, depth, and soundstage back.
  • eztommyd
    eztommyd Posts: 10
    tonyb wrote: »
    She's been surprisingly ok with the height. It's the width that bothers her. Kind of like me. Let me know if you've found the secret formula to figuring women out.
    F1nut Posts: 49,708
    It's width or depth, pick your poison.
    tonyb Posts: 32,902
    eztommyd wrote: »
    tonyb wrote: »
    Ha....you betcha. In general though, women like things aesthetically pleasing. They don't want things that look old, in a room with modern furniture. They place value on looks over sound, where as men usually place sound over looks.
    I'm gonna through a suggestion at you that might satisfy her requirements on width, and yours on sound.
    Tekton speakers. Go to HIFI Shark and type it in, some good speaks on the used markets. Look at the Pentagon or Double impacts. Looks may not be as pretty as some others, but the sound will kick the snot out of many other more costly options. They are also easy to drive with any receiver, but most would put an amp on them anyway for the dynamic presentation.
    For Polk speakers.....the LSIM 705'S is where you want to be hands down, for current models. Good luck to you.
  • Mikey081057
    Mikey081057 Posts: 7,127
    If it's a beautiful sound stage you yearn for check out Usher.
    Garage | Polk Monitor 5B's
    Toolfan66 Posts: 16,834
    There needs to be some give and take in a relationship IMO, it's my house as well as hers. Now I get it if you have gear everywhere and it looks like just a guys pad, but if it's placed well and you have a nice setup than there shouldn't be a problem.
    My wife dosen't like the big speakers, but she is glad that I have them looking nice, and that I got rid of the wood look on them ( so am i ) but when the stereo is on she loves how they sound, and she has enjoyed it as time has gone on..
    Now the HT setup she has no issues with, for one it's in the basement, second she likes the look of the LSiM's as well as the RTiA's when we had them...
  • eztommyd
    eztommyd Posts: 10
    So I just hooked up the A9s. Wow. Just an amazing difference from the Signature Series. They have that perfect Polk balance in tone - subtle bass that's not in your face, neutral mids and crystal clear highs. If you remove the interconnect cable from the SDAs, this is just as good.
    F1nut Posts: 49,708
    No, it's not.
  • eztommyd
    eztommyd Posts: 10
    Having owned SDAs for 33 years, I can tell you that it is.
    edited July 2018
    Listening to SDA's w/o the cable is NOT good (IMO). BTW, who would listen to SDA's without the cable, that's just silliness. The speakers were designed to sound their best with the cable operational. It's a huge handicap to run them without. The A9's must be lacking then.............my Modded SDA 1C's are sure lacking when the cable is unplugged.
    In summary if the A9's sound like SDA's w/o the cable, then that's not a good thing and one should steer clear of the A9's
    Of course you don't mention which SDA's. Each generation was different in design and how the inter aural crosstalk was handled. The last 2 generations of SDA's being the best as they had time to fine tune the system.
  • eztommyd
    eztommyd Posts: 10
    Let me clarify. My point was the tonality sounds as good, not that the depth achieved via the SDAs is still there. Of course you wouldn't listen to SDAs without the cable.
    heiney9 wrote: »
    I think he had/has SDA-2a’s.... I found them to be nowhere near as good as later models.
  • eztommyd
    eztommyd Posts: 10
    Jesus Christ - I'm just trying to help anyone out who wondered how the A9s sound....didn't realize I'd get parsed and belittled like this. Awesome forum here.
    eztommyd wrote: »
    To be fair the OP is looking for the depth and breadth of SDA's you say the A9's have the tone. Not exactly what the OP is looking for.
    All I stated was the A9 will never sound like SDA's without the cable.
    Sorry you feel ganged up on, I'm just stating my opinion based on the OP's original comments. No need to take it personally.
