Recommendations for LSiM 7.2.4 Atmos setup.
New24k
New24k Posts: 74
Looking for input on an LSiM 7.2.4 setup.
The setup is for a condo.
50% music/50% movies.
I am tentatively looking at:
705 - fronts
706c - center
703 - surrounds
702f/x - surrounds back
DSW PRO 660 wi - dual subs
Either OWN5 or OWN3 as on-ceiling Atmos speakers.
I know there are better subs - but I would like to keep everything Polk! :)
  • rpf65
    rpf65 Posts: 2,127
    The 705’s work well in medium to largish rooms, 703’s work better in smaller rooms. So first question is room size.
    The 706 is a really big center, I know, I have one. I have a full size component on each side of this thing and the stand is 70 inches wide. Probably could have had everything touching, and hanging off the sides, and gotten away with 65, but probably wouldn’t be ideal. Just saying, make sure you have room.
    I personally prefer bi/di-pole speakers as surrounds as surrounds and direct firing speakers for rears, so you may want to experiment.
    Yes, there are much better subs than what Polk offers, but if you want all Polk, it’s your money.
    If you decide the 705’s will work, suggest you get an amp. Ran them off an AVR for a while, and after adding an amp, completely different sounding speaker, at least to my ears. They really like current to make them happy. Give it to them, and they will make you happy.
  • rooftop59
    rooftop59 Posts: 7,973
    That’s a lot of speakers for a condo! But I’m sure it will sound awesome!
    I also think you would be happy with the 703s, but they also need an amp imo.
    There is no good rationale for buying Polk subs. subs aren’t timbre matches, and who cares if they all have the same name on them? For a similar price dual HSU or svs are just so much better...
    Game Room 5.1.4:
    Bedroom 2.1
  • gumbay13
    gumbay13 Posts: 360
    New24k wrote: »
    705 - fronts
    706c - center
    703 - surrounds
    I believe you should be just fine with your selection.
    Maybe you can also glean something from this.
    https://www.avsforum.com/forum/89-speakers/2182753-polk-dolby-atmos-7-1-4-demo-cedia-2015-a.html#post38393257
    AMP/Pre Pro: Outlaw 7000x, Marantz AV7703
    Speakers: Fronts:LSiM 705s/ Center: LSiM 706c / Surrounds: LSim 703s
    SUB: Rythmik LV12R x2
    Source:OPPO UDP-203
  • shs
    shs Posts: 105
    I use 705 for front left and right, a 703 for the center, 4 702 f/x for surrounds and 4 TL3s with Omnimount for on ceiling Atmos. Easy to aim at MLP. The TL3s are small, but have the same tweeter as the LSiMs. They sound fine. I'll upgrade if Polk introduces a larger version with the ring radiator tweeter of the LSiMs.
    SONY VPL-VW385ES, Da-Lite 92" 0.9 HD progressive 16x9 screen, Apple TV 4K, Oppo UDP 203, Anthem AVM 60, D-Sonic 4000 (800x3, 400x4) for bed layer, 2 Crown XLS 1002 (225x4) for Atmos; Speakers: Polk LSiM 705s, 703 front, 4 702F/X surround, 4 Polk TL3 (Atmos), Velodyne DD15 Subwoofer.
