Pros and cons of multiple subwoofers
  • EndersShadowEndersShadow Posts: 15,659
    I don't think there is really any con to multiple subs other than additional footprint being taken up.
    The only real downfall is the potential extra time needed to get them to constructively align.....
    Its taken me a bit to get to where I feel they are complimenting each other and work well in my room....
    But the extra time spent and the result are WELL WORTH IT, so dont get me wrong...
    I'm a HUGE PROPONENT of AS MANY SUBS as you can get into your room as extra overhead is ALWAYS a good thing, it means you need less power, have less THD....
  • gp4jesusgp4jesus Posts: 1,137
    edited July 2017
    The two Surround subs are just 12.5" cubed - easy to place.
    I agree - the Starfish effect. Choose cafefully, though. Quality over quantity.
    In my case, the front sub does the CC's heavy lifting & LFE duties only. To set the Surrounds to Large I must set the LR* to Large.
    *Good to the low 30s
    I pray the 976 allows independent setting of Large or Small as I choose. Of course if I happen across another B1.39 or two more Evidence subs, well...
    I'll cross that bridge when I get there. Tony
    Samsung 60" UN60ES6100 LED
    Outlaw Audio 975 Pre/Pro
    Samsung BDP, DirecTV Rcvr, Xbox 360, Dennon LDP, Phillips CD chgr
    Canare 14 ga - LCR tweeters inside; CC outside
    BJC 10 ga - LCR mids, inside & out
    8 ga Powerline - LR woofers, inside & out
    LR: tri-amped RTi A7. Woofers, Rotel 98X amp; M & T, P'sound HCA-1000
    CC: Rotel RB985 -> tri-amped CSi A6
    5 Audio Pro Subs: 1 B1.39: 1 Evidence at each corner
    Surrounds: Hafler XL280 -> AR 12 ga -> RTi A3*
    3 dedicated 20A feeds; APC H15; 4 Furman Miniport 20s
    *Bi-amped by years end
  • gp4jesus wrote: »
    The smallest dimension on my subs are 24".
  • honestaquarianhonestaquarian Posts: 1,950
    Two subs were definitely better than one. Three were certainly better than two. Now let’s see how number four pans out. B) o:)
    Living room Home theater: Upgrade Company modified Onkyo PR-SC5509,Sunfire Cinema grand Signature 5 channel amp(1st gen),Carver TFM-45,Carver M-400a,Panasonic TC-P50ST60 50" Plasma(last gen before Plasma production stopped)Pioneer Elite DVL-91,Meridian 519 Dolby AC-3 RF Demodulator,Oppo Digital UDP-205,TiVo Bolt VOX,Nakamich BX-300,Technics SL-1200MKII,Shure V15 Type VxMR cartridge,Polk SDA-SRS 3.1 TL(with RD-0198 tweeters, upgraded with Larry's rings, black hole5,an Avel-Lindberg 1000VA isolation transformer, VR3 customer crossovers and internal wiring),Polk CS-1000P(with SL-6506 tweeter),Polk Monitor 5jr(with RD-0194 tweeters),Polk RT-35i (1),Polk Mini Monitors,Polk PSW150(4)Monster Power HTPS 7000 MKII Signature series,Monster Power AVS 2000 Signature Series,Various MIT,Monster,Upgrade Company and Belden interconnect,power,HDMI,Coax and Toslink Digital and speaker cables.
    Bedroom 2 channel system:Integra DTM 40.4,Nakamichi BX-100,TiVo mini,Musical Fidelity X-LPS,X-PSU,Carver TFM-25,Sony KV-34XBR970(last of the widescreen tube sets before production stopped)Technics SL-1200MKII,Shure V15 Type V MR cartridge,Polk RT-55(with SL-6506 tweeters),Polk PSW-200 in plexiglass(2),Sony Playstation 3 slim.Monster Power HTPS-7000,Monster AVS-2000, PowerVarious Kimber,Audioquest and MIT interconnects and speaker cables.
    These days each “corner” has its own sub - by EXO for their respective channel. Further, a 5th sub, good to 20hz, connected to my Prepro’s sub out - performing LFE & the CC’s heavy lifting.
    Crazy? Maybe but movies & music are a real kick.
    Side note: some one earlier comented about “Interstellar*” popping breakers. Is that* a movie?
  • Airplay355Airplay355 Posts: 4,182
    edited July 1
    Yes sir, sure is
    https://www.imdb.com/title/tt0816692/
    You guys must have some serious theater rooms. I can't imagine using another sub. I'm afraid the windows are going to blow out as it is.
    Airplay355 wrote: »
    Yes sir, sure is
    @Airplay355 It's not about getting more bass necessarily. Multiple subs will work to break up the standing wave issue that ALL rooms have and therefore give you BETTER bass. That plus the fact that more means that each one doesn't have to work as hard.
    So it isn't just about maximum output (although for some bass heads it might be) It's about smoother frequency response and better quality bass that isn't being mucked up by the room.
    “Yup!” (and therefore) “I’m not a bass head.”
    gp4jesus wrote: »
    Hey @gp4jesus
    Since my CS1000p center has built in subs with power ports, does technically mean I have five also?
    Okay all four subs (*well five if you wamt to include the subs in the CS1000p center speaker*) are set up and running. Four is DEFINITELY BETTER than two! I'm not hearing as many issues with the usual room induced peaks and valleys (caused by standing waves) AND there seems to be a bit more impact on transients that I didn't expect to hear-like sudden sounds that come out of nowhere that they love to mix into movie soundtracks in order to startle you. Something falling to the floor for example.
    Watching the reboot of The Mummy with Tom Cruise.
    Bass is amazing!
    Excellent transient impact and no boom whatsoever when the THX processing with the Audyssey EQ is turned on. Dolby True HD is sounding gooooood :)
    edited July 8
    I think no.
    Having a CC F3 of 35hz is great. RTi A7 & 9s “subs” dig into the low 30s too. But most would agree “they ain’t the real deal (true subs).”
    Most would agree, “...at minimum well into the 20s.” Some would argue “you’re not serious unless” you’re in the the high teens at 90+ dB, under 10% distortion.
    Tony
    gp4jesus wrote: »
    I think no.
    Tony
    Using that stringent criteria then most subs that are being sold out there in the marketplace would not qualify as true subs then.
    Oh well I’m just having fun with this (*after all fun IS what this is supposed to be all about riiiiiiiiight??*)
    Was watching Justice League on HBO yesterday with one of my former audio store bosses and there was this bass note that was really deep which partially pressurized the room. All of a sudden I can’t recall what scene it was in. I bought the 4K Blu-ray combo pack week before last and now I can’t wait to pop it in the Oppo! B)
  • rpf65rpf65 Posts: 1,694
    gp4jesus wrote: »
    I think no.
    Tony
    Read this 4 times and guess you’re excited about your purchase, but don’t know why.
    rpf65 wrote: »
    gp4jesus wrote: »
    I think no.
    Tony
    @rpf65 Neither do I. I'm just happy!
    I guess that makes me a bad man??? :'(
    If you’re so happy about audio that you confuse yourself, you’re in the right place.
    That sounds like something between a motto and a maxim.
  • ZLTFULZLTFUL Posts: 4,480
    Now watch "A Quiet Place"...it has some dips that rival the sine wave signal at the beginning of "Edge of Tomorrow"
  • gudnoyezgudnoyez Posts: 6,199
    ZLTFUL wrote: »
    Just got the 4K release of this movie not sure if we were going to watch it on the big rig or the bedroom rig, with out the characters being able to speak, is it worth a go in 7.2 then due to sound effects?
    @ZLTFUL @gudnoyez
    What is that movie about again??
    Horror flick...monsters that hunt by sound.
    Steve, the ambient noises make it a good atmospheric movie. Lots of other animals and noises to hear and when the monsters are moving around in the woods or a corn field, it produces a lot of surround effect.
Howdy, Stranger!
