WTB Larry's Rings for SDA-CRS
Taking a flyer before starting to drill holes for HNs. This is the 2 tweeters, 2 midwoofers model (1984). Thank you!
  • Faustin
    Faustin Posts: 1,149
    I believe westmassguy is handling the rings now. Check with him.
  • monepolk
    monepolk Posts: 1,141
    I know he had Gimpod's Circuit Boards, but didn't know he had the Larry's Rings.
    pitdogg2 Posts: 24,578
    Faustin wrote: »
    News to me. Fake news that is
  • Faustin
    My bad. Way to early in the morning to be on the puter.
  • Mr_Hz
    Mr_Hz Posts: 176
    edited September 2018
    If you're in between ring cycles (Der Ring des Nibelungen - lol - for you opera fans...? crickets...) you might consider buying/using hurricane nuts - if you haven't already. Almost the same result, and always available.
    2.3TL's - Living Room
    CRS+'s (4.1 TL's) - Office
    SDA1C's - Famdamly Rm
    SDA1C's - Master Bedroom
  • Dr_Wu
    Dr_Wu Posts: 306
    Thanks for the reply Mr Hz. No joy to be found on the ring search. I did install hurricane nuts; they worked out very well. Enjoying the sounds!
    Cheers!
  • mlistens03
    mlistens03 Posts: 2,767
    I must ask, what exactly do Larry’s rings do to improve the sound?
  • Dr_Wu
    Dr_Wu Posts: 306
    They are a mechanical lock down for the drivers. Just help tighten everything up. Improved coupling to the cabinet improves bass response and overall clarity. Also facilitates future mods without risk of stripping wood/MDF screw holes.
    mlistens03 wrote: »
    Lock the speaker driver tighter to the baffle. Screw holes do not wear out.
  • mlistens03
    Toolfan66 Posts: 16,907
    Larry's rings is just a myth, don't listen to these guys, the rings only bring out the dragons from hell..
  • Mr_Hz
    Mr_Hz Posts: 176
    Sorry for the late post, Dr. Wu, especially if this has been covered elsewhere...
    https://www.youtube.com/watch?v=w58E2S315a4
  • verb
    verb Posts: 10,176
    Toolfan66 wrote: »
    Yes, just like Larry's spikes! :smile:
  • lightman1
    lightman1 Posts: 10,776
    Larry is a hack....
  • GlennDog
    GlennDog Posts: 3,085
    lightman1 wrote: »
    Larry is a hack....
    HEY! I resemble that remark . . .
    Source Lumin U1 Mini into Lampi Baltic 4
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
