Joule pre overhaul...
1235»
  • kharp1kharp1 Posts: 2,568
    It gets to a certain point and stops moving and I see no physical binding. Thanks Jesse.
    Main System:
    Joule-Electra LA 100 MKIII
    Pass Labs Aleph 30, McCormack DNA-125, Parasound A21
    Marantz SA-14S1
    Usher CP-6311/Tyler Acoustics Taylo Reference Monitor, LSA-1
    Dual SVS SB2000
    Wireworld Equinox 7 bi-wire, Wireworld Silver Eclipse 7 IC
    Secondary Rig:
    Parasound P5, Audio Electronics by Cary Constellation
    Marsh a200s, Audio Elecrtonics by Cary Hercules
    Pioneer Elite DV-45a, Denon DVD-2910
    Klipsch Epic CF-1, Vandersteen 3CE sig
    Analysus Plus Oval
  • F1nutF1nut Posts: 40,494
    There's a worm gear on the motor shaft that drives the gear which in turn drives the knob shaft. One or both are damaged. These are inside a small metal box attached to the motor.
    This is your pre, see the metal box between the motor and face? Inside are the gears.
    kharp1 wrote: »
    Can you turn it all the way by hand?
    Yes
    Main System:
    Marantz SA-14S1
    Dual SVS SB2000
    Secondary Rig:
    Analysus Plus Oval
    In that case, I'm 99% sure you have a stripped/broken gear.
    I switched the Valvo Hamburg 12ax7 back to the Raytheon 5751 yesterday, and, today when I fired up the tunes it was like flipping a switch with the gain. I'm hearing gain like I would expect. The sound is starting to open up and I'm really liking what I'm hearing.
    Main System:
    Marantz SA-14S1
    Dual SVS SB2000
    Secondary Rig:
    Analysus Plus Oval
  • tonybtonyb Posts: 29,923
    I've read about many owners trying the 12ax7's, nobody really liked them all that much. Judd himself said that they have tried every compatible nos tube in his circuit, and the ones that came with the Joule's and that he recommends, are the best to his ears.
    HT SYSTEM-2 channel
    Dynaudio Audience 72
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    Analysis plus crystal oval ic's
    B&k 1430
    Tad 803 speakers
  • heiney9heiney9 Posts: 23,879
    tonyb wrote: »
    Every NOS, that's a lot of tubes! Not at all doubting the 12AX7 doesn't seem to be a good fit, but that's a LOT of tubes if he means "every" NOS 12AX7/ECC83. Just the Euro variations are staggering. Must have been several years of development just to test every tube in the circuit. That's dedication, for sure.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass
    Pass Aleph 30 | EE Avant Pre | EE Mini Max Plus DAC | MIT Shotgun S3 | MIT Z P/C's | updated SDA 1C| SQ Box Touch/Welbourne Labs P/S- Tubes add soul!
    To be fair, he didn't say every variation of every tube. lol
    You remind me of that movie where you can't make a noise or the monsters will hunt you. A mention of tubes, and your on the hunt. lmao
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
    edited July 11
    Just pulling your chain, Tony :D :p . Wasn't meant to be sarcastic, just bustin' you a little. You know, like you like to do on occasion. Things have been pretty dry and uneventful around here.....................
    Post edited by KennethSwauger on
    heiney9 wrote: »
    Oh, that's just great...start a war with the mob! :)
    Main System:
    Marantz SA-14S1
    Dual SVS SB2000
    Secondary Rig:
    Analysus Plus Oval
    Can't say bustin'
    and nut in the same post apparently.
    LMAO....I know Brock, I can take it as well as dish it out. :)
    Want to hear more from the man about the Joule. C'mon Kerry, we don't care if you have to type in your underwear. Maybe Ryan does, rainbow colored stuff and all. ;)
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
  • maxwardmaxward Posts: 164
    Any additional thoughts regarding the modification, Kerry?
    Thorens TD-160C; Sumiko Talisman S; Jolida JD9; Marantz CD-53; Micromega Mydac
    Joule-Electra LA-100; Balanced Power Technology AC conditioner;
    Odyssey Khartago monos (with most factory upgrades); Magnepan MG 3.6R
    I have an incredibly deep stage. The sound was good before so it's not a monumental improvement in most areas, but, the stage has increased everywhere slightly. The depth was a monumental improvement. Still fleshing out the rest of it. Noticing improvement in individual instrument and vocal separation.
    The first thing I noticed was bass detail. It has become more detailed and articulate. That still impresses me.
    Main System:
    Marantz SA-14S1
    Dual SVS SB2000
    Secondary Rig:
    Analysus Plus Oval
    Great! Thanks.
    Kerry, would you say it's retained it's musicality after the upgrades ?
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
    Definitely!
    Main System:
    Marantz SA-14S1
    Dual SVS SB2000
    Secondary Rig:
    Analysus Plus Oval
    Any updates ? How she breaking in ?
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
    Haven't had much listening time lately due to work. I'm not sure I could say it's even broke in yet. I'm liking what I'm hearing so far.
    Main System:
    Marantz SA-14S1
    Dual SVS SB2000
    Secondary Rig:
    Analysus Plus Oval
1235»
Howdy, Stranger!
