Oh Schiit... back to the drawing board
So I got myself a Schiit Gungnir multibit DAC (Gumby). Was waitlisted for a month and it finally got here a week ago. These are notorious for break-in so I put over 100 hours on it before sitting down for a thorough evaluation. I'm sad and disappointed to report that I'm not totally digging the Gumby. I was really expecting good things too because of the stellar reviews all over the web.
To do my review I A-B'd it against my CDP, a Jolida JD-100. Maybe that's not a fair comparo? It's a damn fine CDP. But it is tube gear and the Schiit is not.
Compared to the Jolida the Gumby was simply less engaging, less fun. The Jolida presents a 3D soundstage with considerable depth. The images have substance and form and you can listen into the details of them deeply. The Gumby was a flatter presentation. Instead of 3D sound images arranged in space it presents more of a 2D sound "picture". Noticeably less fore-aft depth to the images. I also noticed distinctly that certain elements of timbre and musical images such as reverb and echos are presented in less detail and substance, almost not present in some cases. Which you would have no idea what you're missing without a comparo to another gear.
One thing the Gumby did very well was higher frequencies. These really stood out as clear and defined. Cymbals and bells were expertly crafted. The downside to that though is a tendency toward fatigue. And maybe lends to the Gumby's overall "dry" feel to its sound.
As a final test I swapped the IC's (AQ sidewinders vs King Cobras) and reran the test. No noticeable changes.
Well, that's my attempt at a review. I am open to any comments or suggestions in my approach. But at this point I've pretty much decided to send it back. Such a bummer after so much research and anticipation. :(
The search for a new DAC will continue...
SystemLuxman L-590AXII Integrated Amplifier|Sonus Faber Cremona Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|Nakamichi RX-202 Cassette
  • rpf65
    rpf65 Posts: 2,127
    Sounds like you prefer the sound of tube gear.
    If I were you that is where I would start refine the search.
    nooshinjohn Posts: 25,034
    So what you are saying is that it sounds like Schiitt.
    Look for a PS Audio PerfectWave II. They can be had for a good price on the used market.
    F1nut Posts: 49,711
    The Jolida is a nice CDP. What tubes are you using? Why do you feel the need for a DAC?
    Clipdat Posts: 12,560
    Interesting review, thanks for sharing. I think I would certainly expect more from it, given the price point.
  • Jetmaker737
    Jetmaker737 Posts: 1,000
    Jolida has Psvane 12AX7's. The DAC is for streaming (Roon/Tidal). In my tests I was streaming FLAC at 44.1k 16 bit via Roon (no DSP) and Squeezebox touch over wifi
  • Jetmaker737
    DSkip wrote: »
    Jet, are you interested in trying a North Star DAC?
    Hi Skip. Yes, I'd like to try it. PM me with details. Thanks!
