The Tale Of 3 Tweeters
Let me start off by saying that I have been using a pair of SDA 2B's since the mid 90's.
I have used the SL2000, the RDO194, and currently, the SL2500, which I find to perform the best.
With the 13Khz peak of the SL2000, and the ringing of the RDO194, plus the rather rough crossover point between the drivers, I have not been completely happy until now.
The SL2500 is smoother and more transparent, with better timberal accuracy, with a small trade-off of being a bit thinner in the low presence range do to using these tweeters without the added capacitance.
I have run various frequency sweeps, and haven't found any obvious holes in the response.
Sony GX900ES, Micromega Stage 3, Micro Seiki BL-51/Grace 707 MKII/Signet TK7e, Polk SDA 2B's w/SL2500's, JVC HA-D990.
«13456
  • F1nutF1nut Posts: 40,206
    It's the wrong tweeter, period.
  • mlistens03mlistens03 Posts: 1,811
    edited June 10
    What he is trying to say is that that is not the correct tweeter for that speaker. It could cause a number of issues, the biggest being a weird impedance, weird phase, a wonky frequency response, and possibly (extremely unlikely) damage to your crossover. Probably not the best idea. Not saying that it won’t work, but it won’t work as well as the original or the RD0 drop in replacement.
    F1, you’ve gotta go into a little more detail when you explain things. I know I would not listen to someone, who when I asked a legitimate question, just said “you are wrong” and left it at that.
    Micah
    Not Tom, or Trey, or Jim
    Main setup:
    Speakers are one of three, Mission Freedom 770 IV’s, Polk LSi25’s, or Polk SDA-CRS (stock XO, SL2000’s, Blade/Blade model). Electronics are as follows: for the LSi’s and SDA’s, a Technics SU-v75 acting as a phono preamp, into a Yamaha RX-v665, into a Crown XLi800 power amplifier. For the Missions, I have a Lafayette LR-1100. Turntable is a Technics SL-3200, with a Shure M97xE. Cables are generic/soon to be replaced garbage.
    An old post I found on AK, from 2013.
    I've always thought the goal of high end audio was not to have your neighbors bang on the wall and say, 'Turn that darn music down' but to have your neighbors bang on the wall and say, 'Tell your friends to go home and you can practice later this week'.
  • xschopxschop Posts: 854
    Can you expound on the "ringing" RD0194's?
  • FestYboyFestYboy Posts: 2,657
    More than anything, the issue is using a TL Tweeter in a non-TL speaker. The XO hasn't been modified to use a 2500 properly. TL mod the XO, and then you'll understand, and also want to grab a pair of 198s.
  • boston1450boston1450 Posts: 5,928
    mlistens03 wrote: »
    Micah
    LMAO
    Randy in Maine
    CRS+ TL'd 198 tweets-RTA15 TL'd 198 tweets
    --All TL upgrades by WMG--
    Cs1000p-Yamaha-Parasound
    MIT speaker cables-Pangea powercords
    SoundMann1 wrote: »
    FestYboy wrote: »
    That wouldn't be entirely correct, as the official specs leave a lot to be desired.
    FestYboy wrote: »
    I already understand what this mod entails.
    FestYboy wrote: »
    That would be a downgrade to the tweeter series I like the least!
    He is entirely correct and the schematics leave nothing to be desired.
    This ringing you're talking about does not exist. You're the only one hearing it.
    Stop trying to reinvent the wheel, it's already been perfected.
  • ken brydsonken brydson Posts: 7,084
    mlistens03, would you like to buy a vowel?
    C'mon he's 14. Do you not remember Sid the kid back in the day
    HT/Main- Panny 50" G10 Plasma, Pioneer SC-1222k AVR, Panny DMP-BD60 BDP, Polk LS90 mains, CS350LS center, LS/fx side surrounds, LS50 surround backs, SVS 25-31PC+ sub, Harmony One
    Office Rig- Marantz 2252B, Denon 2910, Kenwood KD2070 TT, Polk RTA 12B's/ RTA8t
    Sid the kid was smarter.
    Must be your tinnitus.
    Ouch.
    I tend to be very careful with the volume, in order to keep that from happening.
    Sorry F1, I probably shouldn’t have said that, but I think that if you explained a little more, it would be a lot more helpful.
    Main setup:
  • Llama56Llama56 Posts: 2
    Is the RD0194-1 tweeter a better sounding tweeter than the SL2000 unit in my Monitor 10's. I am being told that the RD tweeter is smoother than the SL. I'm thinking of purchasing the RD's at $108 but need to know if it is worth the cost?
    Worth ten times the cost.
  • mhardy6647mhardy6647 Posts: 18,753
    Oh. I just LOL'd.
    Almost spewed iced coffee, too.
    "It's like watching a roomful of people who couldn't get through college algebra discussing the flaws of quantum physics theory. I guess it could be fun, but it's ultimately a waste of time." -- seen on audiokarma
    "Some amps run on self bias, some amps run on fixed bias. But his amps run on confirmation bias." -- seen on audioasylum
    "Writing about hifi is like dancing about architecture" -- paraphrasing some wag (possibly Frank Zappa)
  • nooshinjohnnooshinjohn Posts: 18,051
    I need to stop opening these threads without making popcorn first....
    The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with PS Audio NuWave Phono converter, Walker Precision Motor Drive, ClearAudio Stradivari v2 cartridge and Origin Conquerer Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X1 two channel preamplifier Signed by Poppa himself, PS Audio PerfectWave DAC MkII, Krell Evolution 525a CD Player, Pioneer Elite SC-65, Oppo UDP-205 Blu-ray , Sony XBR70x850B 4k, Polk audio AB700/800 "in-wall" surrounds
    edited July 22
    SoundMann1 wrote: »
    I still contend that the best mod I have made to my 2B's is adding SL2500 TriLaminate tweeters!
    It's the wrong tweeter for the 2B's.
    SoundMann1 wrote: »
    The only drawback is 4-Ohm impedance.
    Like I said, it's the wrong tweeter.
    That's fine, I just want to make sure no one else makes your mistake.
    FYI, you can't even call them TL'd as the crossover hasn't been tweaked.
«13456
Howdy, Stranger!
