Carver 4.0t or Acurus A250 or Parasound 2250 v2
CH46ECH46E Posts: 731
What would you take to run RTA12B?
Carver 4.0t or Acurus A250 or Parasound 2250 v2 22 votes
Carver 4.0t
18%
treitz3trav0810daddyjtmpitogo 4 votes
Acurus A250
31%
MrBuhllightman1ConradicleserniejadeEndersShadowboston1450ZLTFUL 7 votes
Parasound 2250 v2
45%
steveinazcfrizzgeorge danielaiconnNotaSuvpitdogg2sgtmick63chumlieClipdatMikey081057 10 votes
Adcom GFA555 mkll
4%
Viking64 1 vote
  • nooshinjohnnooshinjohn Posts: 18,398
    None of the above is not a choice...
    The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with PS Audio NuWave Phono converter, Walker Precision Motor Drive, ClearAudio Stradivari v2 cartridge and Origin Conquerer Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X1 two channel preamplifier Signed by Poppa himself, PS Audio PerfectWave DAC MkII, Krell Evolution 525a CD Player, Pioneer Elite SC-65, Oppo UDP-205 Blu-ray , Sony XBR70x850B 4k, Polk audio AB700/800 "in-wall" surrounds
    edited June 27
  • lightman1lightman1 Posts: 9,900
    Acurus A250
    I beg to differ on your first statement, John. Take into consideration the allowed budget. Then maybe ask what other gear is upstream and downstream. Ask before you judge.... Then offer guidance.
    Acurus A250
    Dang it! You said "not" a choice.... I'll show myself out...
  • EndersShadowEndersShadow Posts: 16,077
    Acurus A250
    lightman1 wrote: »
    Holy crap! Wisdom from Russ...
    Like manna from heaven, happen rarely, and when it does, you notice :wink:
  • tonybtonyb Posts: 29,921
    For the 12b's.....Carver or the Parrasound. With some weight on the Parrasound side.
    HT SYSTEM-2 channel
    Dynaudio Audience 72
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    Analysis plus crystal oval ic's
    B&k 1430
    Tad 803 speakers
  • CH46ECH46E Posts: 731
    I have the Parasound now but kind of itching for something else. I have not heard that Carver 4.0t but i have heard the Silver 7 tube amp and loved it. The 4.0t was transfer function based on the Silver 7. Was hoping it might sound similar.
    I have not heard any Acurus amp, but hear good things about them.
    The m4.0t sounds nothing like the silver 7
  • pitdogg2pitdogg2 Posts: 11,113
    edited June 28
    Parasound 2250 v2
    The Carver 4.0T is the same as a TFM45 both long in the tooth and unless they have been recapped well past the due date for that.....
    I run Carver TFM 45 and a TFM 25 both completely recapped and upgraded by Roland and Bob Carver.
    I have heard both the Silver 7 and 9 neither the 45 or 4.0 sound like them.
    edited June 28
    Wanna trade the TFM45?
    Parasound 2250 v2
    CH46E wrote: »
    sure for $2800.00 cash......
  • trav0810trav0810 Posts: 1,014
    Carver 4.0t
    I must say, I really do like the combination of the M4.0t and the Polks. I've never heard the Acurus, so I can't judge it.
    The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
    Sony Playstation 3 for CD and Streaming
    Thorens TD320
    Modified Carver C-1
    Carver TFM 42 and 45 Amplifiers
    Polk RTA15TL Speakers w/Decato mods
    White Lightning Moonshine DIY Speaker Cables and Interconnects
  • treitz3treitz3 Posts: 12,513
    Carver 4.0t
    tonyb wrote: »
    I will concur but swap out your suggestion. The Carver 4.0t is one of my favorite sound signatures from the Carver lineup and it pairs well with Polk speakers. Not a big fan of the sound signature of Parasound.
    Cooter has wisdom? *falls to floor*
    Shut up Russ.
    In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence.
    The best way to enjoy digital music reproduction is to never listen to good analogue reproduction.
  • F1nutF1nut Posts: 40,494
    CH46E wrote: »
    Not even close.
    What speaker cables and IC's are you using for the 12b's and amps ?
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
    Audioquest Diamondback RCAs. . And regular speaker wire due to the long run. I have audioquest cv8 but cant use them :(
    CH46E wrote: »
    Could be why the Parasound isn't tickling your fancy. Hard to make judgements on amps if the cables aren't up to snuff.
    How long of a run are we talkin' anyway ? 12-15 ft ?
    The 12b's are on the warmer side imho, with a bit of emphasis on the lower frequencies. Any amp too warm may just bring that out too much.
    The Acurus has a bit more emphasis on the lower regions which may not pair well. The Carver is more even balanced, and the Parasound isn't as warm as the earlier HCA series, which is why I'm kinda shocked you don't care for it.
    See if you can move things and try your CV8 speaker cables on them, just to get an idea of the sound....and go from there.
    HT SYSTEM-2 channel
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    B&k 1430
    Tad 803 speakers
    45 ft runs. Fished the walls up to the attic, across the room then down the wall again.
  • mlistens03mlistens03 Posts: 2,236
    edited June 29
    CH46E wrote: »
    Yikes! That’s a long run of cable. Though you could probably get a spool of Blue Jeans cable and cut it yourself.
    Micah
    Main system: Technics SL3200, Shure M97xE, Lafayette LR1100 for tuner, Hagerman Audio Labs Bugle 2 phono stage, NAD C352 integrated, Boston Acoustics VR 2, Boston PV500, generic ICs, and BJC Belden speaker cables.
    Desktop: Dell Precision 690 running iTunes, Yamaha RX-v665, Monitor Audio R90s, Velodyne VA-907, generic ICs and speaker cables.
    I've always thought the goal of high-end audio was not to have your neighbors bang on the wall and say, 'Turn that darn music down' but to have your neighbors bang on the wall and say, 'Tell your friends to go home and you can practice later this week'.
    mlistens03 wrote: »
    CH46E wrote: »
    I forgot about blue jeans! I already put some bulk wire in. Not going to be getting in yhe attic anytime soon. Have to wait until nov or dec here in FL. Too dang hot.
    edited June 29
    Parasound 2250 v2
    CH46E wrote: »
    mlistens03 wrote: »
    CH46E wrote: »
    Sissy.... :D :D :D
    You could go to have inc. and buy a spool of Canare 4s11 for like 300.00
    That’s what Russ is for....
    Acurus A250
    Will work for beer and smokes...
    lightman1 wrote: »
    You in Florida?? :)
    Acurus A250
    Not yet. Still in Iowa. Heading back to Indiana Monday. Florida has come up in conversation with home office for a big project for FDOT.....
  • boston1450boston1450 Posts: 5,929
    edited June 29
    Acurus A250
    Florida 40acre truckstop. Brings back memories :)
    Randy in Maine
    CRS+ TL'd 198 tweets-RTA15 TL'd 198 tweets
    --All TL upgrades by WMG--
    Cs1000p-Yamaha-Parasound
    MIT speaker cables-Pangea powercords
Howdy, Stranger!
