LSiC crackle when playing pink noise
Picked up two LSi15's and a LSiC from CraigsList recently, powered by two Rotel amps I picked up earlier this year.
The center channel tweeter has a crackle. First noticed with movie audio. Tested with pink noise played through multiple amps, multiple channels, multiple connects, and multiple speaker wires. Definitely the speaker, and not the content or power system.
I don't think the tweeter is blown. I could test it in the other speakers. Fairly certain it's something in the crossover. Based on the known issues with resistors, I ordered new resistors to try first.
http://forum.polkaudio.com/discussion/162585/lsi15-tweeters-not-working#Comment_2064018
https://www.parts-express.com/mills-2-ohm-12w-non-inductive-resistor--005-2
They come in next week. Will post updates.
The LSi15s sound great. Dialed them in today.
  • mlistens03mlistens03 Posts: 2,230
    tn2036 wrote: »
    good luck with the repair! The LSi series is awesome, and you will enjoy them.
    Micah
    Main system: Technics SL3200, Shure M97xE, Lafayette LR1100 for phono and tuner, NAD C352, Boston Acoustics VR 2, Velodyne VA-907, generic ICs, and BJC Belden speaker cables.
    Desktop: Dell Precision 690 running iTunes, Yamaha RX-v665, Monitor Audio R90s, Boston PV500, generic ICs and speaker cables.
    I've always thought the goal of high-end audio was not to have your neighbors bang on the wall and say, 'Turn that darn music down' but to have your neighbors bang on the wall and say, 'Tell your friends to go home and you can practice later this week'.
  • F1nutF1nut Posts: 40,487
    It's not a resistor, you have a bad tweeter.
    edited June 21
    But he said he switched the tweeters around, and the noise stayed with the cabinet, not the tweeter. I thought the same as you when I first read the post, until I read that.
    Edit: oh you said you COULD, not you DID. In that case, it probably is the tweeters voice coil rubbing the side of the motor assembly.
    Micah
  • tn2036tn2036 Posts: 4
    Thank you; Any ideas for a suitable aftermarket replacement? Just called Polk and they no longer have replacements in stock.
    tn2036 wrote: »
    I know peerless makes some ring radiator tweeters available on parts express, but I don’t think they will work without crossover modifications. I also don’t know if the new LSIM tweeters will work, but it seems unlikely.
    Look on eBay and similar sites to find used replacements.
  • rooftop59rooftop59 Posts: 4,619
    tn2036 wrote: »
    he didn't actually test it in other speakers. Almost certainly the tweet. I know it sounds ridiculous, but if you got a really good deal I would just buy another center on ebay. Either sell the extra drivers or keep them as spares. Finding the proper replacement will be very difficult.
    Someone on the forum was selling a center really cheap. They might sell to you (some of us only sell to active members with 100+ posts, but that's entirely up to the seller).
    HT Rig:
    Denon AVR-X4200w; Peachtree Audio Nova Integrated; Bryson BPD-1; Mains: Dynaudio Emit 10 + MartinLogan Dynamo (original) sub; Center - Polk cs400i; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - SVS PB10-ISD; LG UP870 4K BDP
    Master Bedroom
    Marantz SR-5007; Peachtree Audio NovaPre; Audiosource Amp Two, PSB Imagine B, Boston VR-10 center, NHT Super One CI surrounds, ACI Titan subwoofer, Squeezebox Touch
  • K_MK_M Posts: 1,035
    edited June 22
    what is the going price of the Vifa/Lsi tweeter (used) now?
    I found one damaged on Ebay for $39.99, sounds a bit steep, for a damaged item.
    The brand new Vifa XT25tg30 is only like $32.00 on parts express.....
    Lsi15, Lsi9, LsiC,Rta11t,M5jr+,M4,SDA 3.1TL, SDA SRS 2.3TL, Rti6....Still listing stuff, a work in progress.
    B+W-
    Epos-
    Infinity-
    Advent-
    K_M wrote: »
    Find one and let us know ;)
    HT Rig:
    Master Bedroom
    K_M wrote: »
    But that isn’t the same tweeter. The Vifa tweeters used in the LSi series was better I believe.
    Also, doesn’t the LSi15 have a different impedance tweeter than the LSiC? Or is that just the midbass drivers? If so, then you have to make sure that I feel you buy one it isn’t from a LSi15.
  • VR3VR3 Posts: 22,264
    Polk claims to alter the vifa tweeters, but they simply alter the faceplate, which can be swapped
    - Not Tom
    Vr3Mods.com ///// Version3Audio.com
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
    edited June 23
    mlistens03 wrote: »
    K_M wrote: »
    The lsiC and Lsi15 and all the lsi line use the same tweeter.
    The midbass drivers are wired in series in the Lsi15, and are slightly different in some minor ways, but if I remember correctly they were actually all 4 ohm drivers, but the impedance peak (and Qts) value was slightly different.
    In comparing both midbass drivers (we have several Lsi models) it was not apparent which was being used. So they are not all "that" different in reality.
    B+W-
    Epos-
    Infinity-
    Advent-
    K_M wrote: »
    mlistens03 wrote: »
    K_M wrote: »
    Ok, good to know.
    I had a terrible dream last night where I came upstairs and the cone in both midbass drivers had fallen out and was sitting on the ground, then the dog stepped on them and crushed them. Now I know that I can use the LSi15 drivers! :wink:
    edited June 23
    double Post...
    Post edited by mlistens03 on
    on Parts Express...
    https://www.parts-express.com/peerless-by-tymphany-xt25tg30-04-1-dual-ring-radiator-tweeter--264-1016
    Many commenters / reviews indicating they use this as a replacement for the Polk LSi series
    tn2036 wrote: »
    on Parts Express...
    A lot of people do, but I believe it is a different tweeter, which means that it will sound different. It I should possible that it’s the same, but I doubt it.
    I would just contact @dbryant about his LSiC to see if he still has one left. If so, he has them priced as a steal at around $140, and then you will have every driver except for the tweeer should they go bad in any one of your other speakers.
    Micah
Howdy, Stranger!
