Sunfire 300X2
What preamps are you folks using with this amp?
    txcoastal1 Posts: 13,132
    Tubes man....Tubes :)
  • helipilotdoug
    helipilotdoug Posts: 1,229
    txcoastal1 wrote: »
    What Ron said. The Sunfire Classic Vacuum Tube preamplifier is what I use with the Sunfire 300 X 2.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • trav0810
    trav0810 Posts: 1,056
    I'm using an ARC LS5 with mine. They seem to work very well together.
    The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
    Sony Playstation 3 for CD and Streaming
    Thorens TD320
    Modified Carver C-1
    Carver TFM 42 and 45 Amplifiers
    Polk RTA15TL Speakers w/Decato mods
    White Lightning Moonshine DIY Speaker Cables and Interconnects
    nooshinjohn Posts: 25,100
    Pass X1 works for me...
  • Cylontymany
    What about a Carver C-1
  • helipilotdoug
    Never tried it, but the Carver C-1 should work well too. I like the sonic holography with the C-1, which is not on the Sunfire tube pre.
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
